1978 - 1996 Big Bronco
starter doesnt
Old Sep 24, 2003 | 01:10 PM
Bustedbronco's Avatar
Bustedbronco
starter doesnt
ok, This is my first post
my starter had been making horrible grinding sounds and I knew it was on its last legs. I thought , well I will look into this weekend , but alas, it stopped working last night. When I turned the key it just went whirrrrrrrrrr, spinning but not engaging the flywheel I assume. I got under there and noticed it was really really loose. I tightened the bolts and still same thing happened. I put on a new starter and now it clicks but doesnt start the engine. I read my haynes guide which says its probably the battery. I put in a battery I know is good and the relay started Smoking? I am going today to get a new relay and a new battery to starter wire. I saw alot of similar topics but I never saw a smoking relay issue. What is going on with this thing? Thanks
Old Sep 24, 2003 | 01:22 PM
Kemicalburns's Avatar
Kemicalburns
starter doesnt
you may also need to upgrade to larger cables. if there two small for the power going through them it will cause this.
good luck
Old Sep 24, 2003 | 02:46 PM
frogger01's Avatar
frogger01
starter doesnt
Sounds to me like eiter your starter cable wire is grounding on something or the starter itself is DOA.
Old Sep 24, 2003 | 07:21 PM
Bustedbronco
starter doesnt
ok, I changed the starter, the solinoid/relay, and all 3 cables . I grond the the G-wire directly to the frame......here is the thing, last night at 2 am when I tried to put a different battery in I was in a hurry since I was working at 2 am in the ghetto, and I wanted my truck safe at home, I accidentily hooked up the battery backwards and now everything is dead. I checke the fuses in the fuse block - all good there. I know there is a fusable link on the ignition wire near the relay but I cant find it. What did I cook? the fusable link? What am I missing?
Old Sep 25, 2003 | 10:21 AM
Kemicalburns
a few brain cells lol,
just messing with ya. i have know idea
good luck though
