Brackets in Bed
Old Sep 12, 2018 | 01:08 PM
Undrgrndprdcts's Avatar
Undrgrndprdcts
Brackets in Bed
What are the 4 brackets/plates in the bed for?
Old Sep 12, 2018 | 01:16 PM
BK39's Avatar
BK39
I have the bed cleats locked in mine for strapping down motorcycle. I think if you can buy the stowable loading ramp, it'll lock on there with a bracket.........etc.
https://accessories.ford.com/bed-pro...own-11854.html
Old Sep 12, 2018 | 01:42 PM
BlackOps450's Avatar
BlackOps450
There should be a present for you to use on those brackets under your rear seat driver side.
Old Sep 12, 2018 | 02:03 PM
Turbo Dog's Avatar
Turbo Dog
Anybody know how much weight they can hold? I haven't used mine for anything yet, I've only used the lower metal ones.
Old Sep 12, 2018 | 04:04 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
You can also use E-track attachments with them.
Old Sep 12, 2018 | 05:51 PM
GMoney1121's Avatar
GMoney1121
There are a bunch of accessories, both Ford and aftermarket, that use the boxlink system. You can also use etrack attachments with them, which opens up a whole new level of uses.
Old Sep 13, 2018 | 10:11 AM
Undrgrndprdcts
Thanks guys. I don't think mine came with any attachments under the back seat.
Old Sep 13, 2018 | 10:14 AM
BK39's Avatar
BK39
if you bought it brand new, go see your dealer. It should have came with the cleats. Everything else is an accessory. The Cleats come from factory with the truck, or at least my 17 did.
Old Sep 13, 2018 | 10:42 AM
Undrgrndprdcts
Hmm I'll have to check harder. Mine is an XL.
Old Sep 13, 2018 | 12:36 PM
Wes_Forged Authority's Avatar
Former Vendor
It's always difficult loading cargo and having the right hook locations, or something is in the way, etc. We actually came up with a solution for that.. our mounting rail system hooks on your bed header, takes up little room, and everything is modular. Pictures below!
Old Sep 13, 2018 | 01:44 PM
hi3cho's Avatar
hi3cho
My XL didn't come with the brackets, or the mounting plates pre installed. It does however have the mounting holes for the brackets, which maybe what you are talking about. I would take a look at your sticker and see if they were to be included. If you have the mounting plates, I assume you were supposed to get the brackets.
Old Sep 13, 2018 | 02:13 PM
Undrgrndprdcts
I definitely have the mounting plates, as well as in bed lighting. I either didn't notice the brackets, or my dealer screwed me.
Old Sep 13, 2018 | 02:29 PM
6.2caribou's Avatar
6.2caribou
They come blister wrapped to a piece of cardboard backing...maybe 5"x8" in size. 4 cleats/brackets with 2 keys. Mine were stashed under the back seat.
Old Sep 13, 2018 | 02:53 PM
Kyle44k's Avatar
Kyle44k
when I bought mine it had the cleats installed already any idea where the keys would be??
Old Sep 13, 2018 | 05:18 PM
honda250xtitan's Avatar
honda250xtitan
glove box probably
