My 1950 f 47
Received 4,182 Likes
on
on
Yes they were my Dads so I built a shelf .Couple weeks ago I met a guy and he said he had a old ford 1/2 ton in northern Alberta in the bush so I went and looked at it pretty ruff cant even see if it has axles you can see the top of the springs going down into the dirt I think its a 53 going to dig it out this Wednesday and haul it home ill post some pictures kinda a barn find with no barn
Thanx,
I've been trying to figure out the differences between the F-47 and the F-1. Although they are very similar, there are some key differences.
In 1950 there was no 'globalization'. Literally every single piece of your truck was made in Canada. If you are lucky you may even find some of the original ford lightbulbs in place. They will be stamped made in Canada.
One of the differences i've been trying to sort out is the box. These days most boxes that are in good shape are after market replacements from the US.
My 1950 box has 9 boards with a wider center board and FORD block lettering on the tailgate.
In the USA they used 8 boards that were evenly sized, and they switched from the script lettering to block lettering later than we did.
I believe we changed to block lettering in mid 1950.
Your truck is in excellent shape, so your project should roll along smoothly. Keep us updated with lots of pictures.
Kirk
Kirk
