Aerostar Ford Aerostar
Wiper arm replacement
Old Sep 24, 2003 | 10:26 AM
ChrisWComcast's Avatar
ChrisWComcast
I'm having difficulty in retro-fitting some replacement wiper blade to my '93 LWB. Bosch MicroEdge (use on my Voyager and love them) states compatibility with my Aero, yet I can't seem to find any sort of release mechanisim for the existing arms. HELP!!
Old Sep 24, 2003 | 11:37 AM
Pagemaker's Avatar
Pagemaker
Is it the wiper arm or the blade?
Either one you can get off with a regular screw driver.
Let me know which and I'll post a picture of what you are wanting.
Old Sep 24, 2003 | 11:42 AM
ChrisWComcast
I'm trying to replace the part of the wiper arm that actually holds the blade. The spring is completely sacked on one side and actully broken on the other. Thanks.
Old Sep 24, 2003 | 12:29 PM
Pagemaker's Avatar
Pagemaker
1. Cycle arm and blade assembly to where removal of blade assembly can be performed without difficulty. Turn ignition key off at desired position.
2. To remove blade assembly, insert screwdriver in slot, push down on spring lock and pull blade assembly from pin.
3. To install, push the blade assembly on the pin so the spring lock engages the pin. Make sure the blade assembly is securely attached to pin.
Old Sep 24, 2003 | 12:30 PM
ChrisWComcast
Talking Wiper arm replacement
Thank You! Thank You! Thank You! Thank You! Thank You!
Old Sep 24, 2003 | 12:37 PM
Pagemaker's Avatar
Pagemaker
1. Raise arm off windshield to specified dimension. Refer to Dimension Chart in. Move slide latch away from pivot shaft.
2. Remove blade and arm assembly.
NOTE:
No tools are required to remove blade and arm assembly. For installation, follow removal procedures in reverse order.
Old Sep 24, 2003 | 12:41 PM
Pagemaker's Avatar
Pagemaker
I'm going to have to replace my wiper arms, I have already replaced them with some from a junk yard, but they are no better than the ones I had.
My wiprs tend to "float" at highway speeds, its as if the spring just don't have enough tension to hold them against the windshield.
Old Sep 24, 2003 | 01:44 PM
ChrisWComcast
My situation is just the opposite. Wiber arms are new, but the blade assy.'s are crap.
