'89 Brake Upgrade Options
Old Sep 11, 2018 | 02:48 PM
Fordyote's Avatar
Fordyote
Done some searching win here and on the ole google machine and im not seeing many options for reliable brake upgrades for an '89 F-150. I was hoping fo find something a little more robust than a $22 brake caliper. Now to be honest I don't have a reason that I need a bigger Badder brake caliper I.e. super fast truck or heavy towing, but I would like to have the piece of mind that I have a quality product stopping my truck. Thanks for any direction anyone can provide.
Old Sep 11, 2018 | 10:58 PM
westcoasting's Avatar
westcoasting
What do you mean by quality product? Buy the ford pads and rear shoes, as good as quality as there is. No need to upgrade anything the stock brakes will be more than adequate for your needs.
Old Sep 12, 2018 | 06:30 AM
Adambomb945's Avatar
Adambomb945
Paint your new OEM calipers red and throw a Brembo decal on them. Instant upgrade. Cant get any better than OEM.
Old Sep 12, 2018 | 06:51 AM
arse_sidewards's Avatar
arse_sidewards
Replacing the stock booster with a hydroboost or the larger vacuum booster from a F350 is generally the cheapest and easiest way to improve braking performance.
Old Sep 12, 2018 | 04:10 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
It's an F150, not a super duty. If the truck can haul/tow it the original style brakes can stop it (depending on the operator).
Old Sep 12, 2018 | 04:23 PM
85e150's Avatar
85e150
Have the calipers checked or otherwise try to find out if you have plastic pistons or steel. Once you have the steel, then it's on to making sure your other components (like the hoses, check the hoses!) You can experiment with high dollar pads, but the basic problem is these are small rotors and single piston brakes. Other than the plastic pistons, the quality of OEM brakes is fine. You just have to operate within the limitations.
cusz721
Jun 14, 2019 06:05 PM
marcrex
Apr 10, 2019 12:47 PM
T-Bone_600
Oct 27, 2004 08:04 AM
Johnny Mo
Aftermarket Products
May 3, 2002 11:35 PM
