6.2L V8 Discuss the 6.2L V8
Rpm
Old Sep 10, 2018 | 09:02 PM
rled's Avatar
rled
Rpm
What is the highest rpm you feel comfortable revving your engine on a semi regular basis?
Old Sep 10, 2018 | 09:07 PM
82_F100_300Six's Avatar
82_F100_300Six
I don't rev mine too much but if I was working it towing heavy on some hills and stuff probably 4500 or so
Old Sep 10, 2018 | 09:52 PM
Kevinm1980's Avatar
Kevinm1980
Mine goes up to 4000 towing, pretty much the highest it will go regular driving, occasionally will go higher if I need heavy acceleration getting back on highway
Old Sep 11, 2018 | 10:00 AM
ibdagriz's Avatar
ibdagriz
I've pulled several hills that dropped it into 3rd and we were around 5500 at times while it worked thru the gears.
I prefer to wind them out rather than lug them while towing.120k on it now and runs like a champ still.
Griz
Old Sep 11, 2018 | 10:54 AM
River Wild's Avatar
River Wild
Griz
Same here. RPM = HP
Old Sep 11, 2018 | 11:06 AM
JTPioneer's Avatar
JTPioneer
On the steepest sections of some mountain passes I target 5000 rpm which is about 55 mph in 2nd gear (3.73 gears).
Old Sep 11, 2018 | 12:49 PM
dnewton3's Avatar
dnewton3
Short bursts to red-line don't bother me. (WOT to get around someone, or pulling a short rise)
Moderate runs at 5,000 rpm are totally fine. (say 10 minutes or less in the mountains).
Long runs at 3,500 rpm are completely safe (all day long into headwinds on the highway)
Lugging with no real load isn't horrible, but heavy loads are not well sustained by lugging (diesels excepted). "lugging" must be defined for each case and what each specific engine is designed to live through.
The 6.2L engine program will typically make the engine "lug" lower than I like while in normal drive mode and running empty; to a point of being annoying. The 6.2L is heavily over-square; bore is much larger than stroke and has big valves. She's made to rev!!!!
Old Sep 11, 2018 | 12:54 PM
JTPioneer's Avatar
JTPioneer
The really steep sections are typically less than a couple of miles. I pay close attention to the engine and transmission temps - never been an issue even on the hottest summer days. Really impressed with this powertrain.
Old Sep 11, 2018 | 01:07 PM
HST's Avatar
HST
I pull 4500 to 5000 up I-70 at times and no problems.
Old Sep 13, 2018 | 05:31 AM
dnewton3's Avatar
dnewton3
I am about to embark on our first trip out west with my current truck (signature line). I've made many trips out west into/trough the Rockies with my 2006 Dmax and was always impressed with it's ability to pull my RV and never feel "slow".
I'm hoping my F-250 gives me the same safe, strong feeling. My general pre-trip gut feeling is that I'll have to rev her up to make her move, but that is exactly what the 6.2L is designed for; sustained rev's with low stress on the rotating assy (over-square) and cams (shaft/rollers).
I'll put together a report of sorts upon return in a few weeks.
Old Sep 13, 2018 | 07:07 AM
Ron94150's Avatar
Ron94150
Whatever it takes to maintain the speed limit. I've never once worried about it. With that said, even with 10k hooked up, living in East Tennessee at the base of the smokys, I rarely see more than 4-4500k. Using manual mode really helps. Most of your steep mountain interstate passes will have a lower speed limit, so it's not like you have to maintain 70mph.
Old Sep 13, 2018 | 11:11 AM
MBuckholz's Avatar
MBuckholz
Any RPM all the way up to redline all day long, that's the way I drove my '11 6.2L. Ran perfect for a hundred sixty thousand miles, did replace one right side exhaust manifold that cracked/warped at around a hundred twenty five thousand miles. I live at 7000 feet, towed 10k lb travel travel all over the West running 75 to 80 miles an hour. I bet that engine had over a hundred hours of 5500-6000 RPM run time when I sold the truck and bought a new 18 6.2l. I went with 4.30 gears this time and with the both horsepower and torque peak moved down in the RPM range it seems like my new truck can pull a gear taller pretty much everywhere. I did change my oil every 5000 miles and used the best synthetic available on my 11 6.2 liter.
Old Sep 13, 2018 | 01:57 PM
saratoga2011's Avatar
saratoga2011
With the accelerator? To the floor in whatever gear is necessary for however long it is necessary.
Downshifting? It won't let you do anything stupid like drop to 1st on the highway going 85. Pretty sure even in M it will upshift if you get going too fast for the gear downhill.
Any modern vehicle is programmed not to let you blow it up.
Old Sep 13, 2018 | 05:00 PM
Chuck's First Ford's Avatar
Chuck's First Ford
overhead camshafts... are designed to make horsepower and SPIN..... LET IT SPIN....
Old Oct 2, 2018 | 06:39 PM
sky Cowboy's Avatar
sky Cowboy
This ^^^^^
My employees tow heavy in my company pickups regularly.
I feel certain that there is nothing I could ever do to them, that hasn't happened already by staff.
I just plant my right foot to the floor on steep hills, with a heavy trailer in tow, and leave it there. The modern transmission in these trucks are going to keep the engine from hurting itself. These 6.2s pull hard, very hard, I can frequently pass slower traffic climbing a 9% grade with a 14k lb trailer behind me. I can usually maintain the speed limit and pass the gutless vehicles in the slow lane.
