ACT Sensor relocation
Old Sep 8, 2018 | 07:48 PM
Bmoodie10's Avatar
Bmoodie10
Alright folks. Long story short put a new motor in my 91 f150 and got back to hooking up all of my wiring harness and it looks like the intake I bought for it off a (supposedly) 94 f150 does not have the inlet for the ACT sensor on the bottom of the intake manifold. I have no idea why I didn’t notice this earlier but I’m 6 months in the rebuild and now dead in the water. I’d really like to think I don’t have to pull everything apart again now that the motor is in the truck and replace the lower intake. I’ve read enough to know the intake is off a Mass air truck and that the Act sensor is located in the air cleaner housing. Is it possible to go junk yard diving and find a housing that will fit my application and keep things moving? Or with the truck being a SD set up I’m playing with fire. Thanks in advance.
Old Sep 8, 2018 | 08:50 PM
Conanski's Avatar
Conanski
For your EFI system you need the ACT sensor in the lower intake, the one at the airbox will report out of range temps compared to what the PCM expects. You should be able to drill and tap one of the intake runners without removing it from the engine, just make sure the valves are closed on that cylinder and connect a vacuum to the port to remove all debris as you work.
Old Sep 9, 2018 | 11:53 AM
Lead Head's Avatar
Lead Head
I wouldn't risk drilling a hole in my intake without taking it off. If you really don't want to swap the lower intake, your best option IMO is to take the upper intake off, drill and tap a hole in there for the sensor. If you don't want to do that, second best option is to extend the wires and stick the ACT in the air box. The ACT isn't super critical, and would likely work okay there.
Old Sep 9, 2018 | 07:13 PM
Bmoodie10's Avatar
Bmoodie10
while we’re on the subject of missing items. It seems my harness isn’t equipped with a pig tail for a charcoal canister evap solenoid. There was one zip tied to the new throttle body from the newer truck. My Haynes manual wiring diagram says there should be one on the 91 but like I said, no wiring. Is it safe to just run a vacuum line from the canister to the port on the throttle body?
Old Sep 9, 2018 | 08:38 PM
Conanski's Avatar
Conanski
Early trucks didn't have a solenoid the line was just connected to the TB directly. I agree with IAN on drilling the upper intake for the IAT if doing that for the lower makes you nervous, this location should work as well as in the lower.
Old Sep 9, 2018 | 09:00 PM
Bmoodie10's Avatar
Bmoodie10
awesome, thanks for the info.
Blue86f150
Jul 15, 2008 09:48 PM
Jrock909
Mar 5, 2007 02:04 PM
Kwattro
Jan 17, 2006 09:55 PM
M.Herrington
Aerostar
Jul 26, 2004 02:17 PM
jpjshy13
Apr 25, 2004 10:00 AM
