Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Bill rear end numbers.
Old Sep 8, 2018 | 11:22 AM
C600's Avatar
C600
Bill, can you check rear end numbers, I have a couple rear ends that came with a C600 parts truck and wanted to know what they were and if there was an interest in them before I scrapped them, both are 2 spd rears, the first one has what I've been told a Ford number on it, E5BH then 39983, in a little square box is 1319 and a raised number of 31915, I know they are not in the 50's but look to be 70's or so, the second one only has the numbers 19750 and 4242. Both are 6 lug hubs.
I f someone had a use I rather give them a home
Old Sep 8, 2018 | 03:56 PM
85e150's Avatar
85e150
Brake drums would be of value if good. Can't get 'em new anywhere.
Old Sep 9, 2018 | 02:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
These appear to be Eaton two speeds. Look at this pic at the lower left and post the numbers you find in this location.
Old Sep 9, 2018 | 10:42 PM
C600's Avatar
C600
OK,I'll take a picture of where i found the numbers, the first picture has them on a flat pad just above the shaft for the two spd. I don't see any of the rockwell tags but I'll loo to see if there are rivits where they may have been.
Old Sep 10, 2018 | 12:38 PM
wyomingford's Avatar
wyomingford
Depending on interchangeability, I may be interested in the differential out of the second axle to fix my 2 speed Eaton.
Old Sep 11, 2018 | 08:26 AM
C600's Avatar
C600
I'll see what else I can get for numbers.
'18_F250_4x4
Jan 26, 2019 07:08 PM
FordTruckGuy96
1947 and Older Ford Trucks
15
Feb 11, 2017 07:53 PM
afonda
Dec 30, 2008 07:41 PM
reamer
Jan 12, 2005 08:11 PM
