U joint conversion
Old Sep 6, 2018 | 01:10 PM
Rollingscrapmetal's Avatar
Rollingscrapmetal
U joint conversion
My 91 302 5 speed 4wd had a bad 8.8 axle so I took a 9 inch out of a 74 and put it in there
the u joint isn't the same it seems to have fatter caps and is narrower across so I need a new yoke on the axle all I need is what to order because I don't even know where to start
Old Sep 6, 2018 | 01:16 PM
Rollingscrapmetal
Also the sensor in the top of the axle what was that
Old Sep 6, 2018 | 01:52 PM
Mikulh's Avatar
Mikulh
I can't help you on the U-joint, but the sensor on the axle is for ABS.... Not necessary, but it may cause you to have an ABS light on if not hooked up.
Old Sep 6, 2018 | 09:44 PM
Dean06919's Avatar
Dean06919
You can probably find a conversion u joint. I needed one for my F350, it was a Moog 448.
Old Sep 7, 2018 | 03:43 PM
Rollingscrapmetal
As far as I can tell the 9 inch accepts a 1310 big cap u joint
the 8.8 has for sure a 1330 so all I need is a 1330 u joint easy day
Mrarmyant
Apr 2, 2012 09:27 AM
rancid
Nov 26, 2006 08:14 PM
rc4man
Offroad & 4x4
Jan 10, 2002 01:16 PM
