Engine running rough ('93 302)
Old Sep 6, 2018 | 12:09 PM
OlBlue93's Avatar
OlBlue93
So, my 302 has been running rough for a while now, & I've tried almost everything I can think of that would cause it, with each parts replacement making it a little better, but not actually fixing it. I replaced the plugs & wires less than a year ago, then more recently I've replaced the air filter, IAC valve, fuel filter, EGR, Oxygen sensor, tried a new MAP sensor, & did the distributor cap & rotor this morning. Other issues have fixed themselves in the process, but I still feel a light miss while driving (especially around 1500 RPM) & roughness while idling probably about 80% of the time. Just want to see what suggestions y'all have. I plan on pulling plugs later today & checking them out, but I'm running out of ideas. I've pulled codes, only got the "111" all clear code, & I figure the engine running test would've caught the TPS if that was the issue.
Old Sep 6, 2018 | 12:17 PM
rla2005's Avatar
rla2005
Make sure the plug wires are properly routed and separated to prevent cross-fire. A Ford TSB from Steve83 on the subject: 1987-93 5L Plug Wire Routing
Old Sep 7, 2018 | 08:34 AM
OlBlue93's Avatar
OlBlue93
Shouldnt be cross-firing, I made sure to route everything so that 2 & 4 aren't touching, and 7 & 8 aren't either. I'll check again to make sure though.
Old Sep 7, 2018 | 09:48 AM
rla2005's Avatar
rla2005
Be sure you are using the correct firing order: 1-5-4-2-6-3-7-8
1994 and later 5L engines use: 1-3-7-2-6-5-4-8
Not the first time someone has done that. Also a possibility someone installed a later model 5L engine, therefore if you are using the old firing order on a newer engine it will run rough/miss.
Old Sep 7, 2018 | 11:14 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Does it matter the temperature outside/how long you drive it? I would check codes at this point and see if something has logged
spupilup
Apr 27, 2013 07:22 PM
rschneider012
Jun 25, 2012 09:48 PM
teamshadyinc
Jul 1, 2010 11:52 PM
Mr.ford
21
May 6, 2007 11:07 PM
Jimmy Dean
24
Jun 27, 2004 09:00 PM
