1988 F-150 302 won't start
I have recently purchased a 1988 302 with EFI. Engine cranks good, and I can get it to "spit and sputter" if I manually dump fuel in the intake (will not fire otherwise). I have been jumping the fuel pump relay to activate the high pressure fuel pump located on the left side frame rail. When the pump is actuated I have fuel pressure up to the fuel rail and voltage to both wires for the injectors, yet it will not fire. Any ideas what I may be overlooking?
my 93 is doing the same. I have the fuel rail pulled fromthe motor with lines and injectors attached with a remote starter and the ignition in the run position I turned over the engine and found that only 2 injectors are actually working. I did not check the voltage at the injector plugs, how do yo do that and what voltage should be there//
The engine has 99,000 original miles, so I doubt that the timing chain is bad, although I will check this. The reason I doubt the timing chain is bad is because the engine will run if I continue to manually supply fuel to the engine. I haven't had a lot of time to troubleshoot this problem, but I believe that it is either the EEC-IV or a problem with the fuel pressure regulator.
