Vent window attachment
Old Sep 4, 2018 | 12:44 PM
hootvan's Avatar
hootvan
I have a 2005 Excursion with the rear vent windows. I am wondering if anyone has the part number for the socket attachment point that screws onto the vent window and attaches to the ball on the actuator arm. I have googled, looked at the ford parts sites and searched the forums with no luck.
Old Sep 4, 2018 | 03:08 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
If I understand the part you are talking about , it is glued to the window and the actuator is attached to it. A glass shop should be able to help if ithat is what it you are referring to Good luck
Old Sep 4, 2018 | 05:25 PM
hootvan's Avatar
hootvan
The mounting post is glued to the window, but the plastic coupler portion unscrewsfrom the mounting post.
Old Sep 5, 2018 | 11:03 AM
unleashd's Avatar
unleashd
I am not sure that comes as a separate part. All I could find is the full actuator assembly part number.
YC3Z-7830478-AA
Old Sep 5, 2018 | 05:11 PM
01__Excursion's Avatar
01__Excursion
When I recently researched replacing my vent window gaskets, cause they're the last ones to do , my regular dealer advised me that I would have to purchase the vent window glass, this came as a kit with the body gasket channel, gasket, glass, and the glass mounted motor connector. My wholesale cost was about 400.00 - 500.00...
Old Sep 6, 2018 | 09:05 AM
hootvan's Avatar
hootvan
If you end up buying the glass kit, let me know. I would purchase that little connector on your old the windows from you.
Old Sep 8, 2018 | 07:50 AM
bcrewcaptain's Avatar
bcrewcaptain
unsure if it different on drivers or passenger side, but since I am replacing my passenger side with a non motorized window, I can prob pull the assembly for you if it would work.
Old Sep 8, 2018 | 02:02 PM
01__Excursion
I will let you know, it's still on my list to replace those gaskets.
midsouth
Apr 13, 2013 01:29 AM
NASTseventhree
Aug 22, 2011 06:57 PM
rich51fordtruck
Dec 16, 2006 08:34 PM
