i have now have finally my left drivers door fully working (except door lock, i think i need relays for it) only problem is going down it goes sideways but after years the seal made a groove but new seal will fix it.
now my left all manual door will become electric. i orderd a door aculator that uses also the 2 wire setup but the window is still manual. i did a search on car-parts.com and have found the regulator from a 97 f250(hope it fits) but the motor will be a bit hard to find. the only one i found i think its from a tempo rear right door, would it work with the regulator.
oh ouch well I have to go to my local junk yard to try and find a power lock solenoid for my 85 truck if I find one with power locks I bet it will have power windows I'll keep you in mind and give you an email if I find anything. they're really good on there prices.
