Sponsored by: Real Truck
Starting issues
Old Aug 31, 2018 | 01:12 PM
BlueBeauty's Avatar
BlueBeauty
Starting issues
I have an issue of every now and again I go to start my 2003 f250 5.4l and it will do nothing. My starter is two years old battery is also two years old and I just changed my ignition switch. What do you think it could be?
Old Aug 31, 2018 | 01:24 PM
Juneaudave's Avatar
Juneaudave
How do you get it to start after this happens?
Old Aug 31, 2018 | 03:30 PM
BlueBeauty's Avatar
BlueBeauty
I just keep trying to turn it over. Sometimes it only takes one try others it can take 5 tries. Just depends I guess
Old Aug 31, 2018 | 08:11 PM
Juneaudave's Avatar
Juneaudave
So...when you turn the key...it doesn't crank? Could be something like a neutral safety switch, I suppose. Next time it doesn't start, maybe try shifting the transmission into gear then back to park...
Old Aug 31, 2018 | 09:06 PM
BlueBeauty's Avatar
BlueBeauty
Hmmmmm ok I will try that but no it doesn't crank. I hear a low but deep click like it's my starter but the starter seems to be fine.
Old Sep 1, 2018 | 09:00 AM
Djosbun's Avatar
Djosbun
Check condition of battery cables and your ground point. Might have high resistance due to corroded cables under the sheathing.
— Dave
Old Sep 1, 2018 | 11:51 AM
seville009's Avatar
seville009
— Dave
i second this......check the battery cables.
Had a 99 Expedition that did the same thing you describe. New battery cables, problem gone.
Old Sep 2, 2018 | 07:38 AM
BlueBeauty's Avatar
BlueBeauty
Replace the ENTIRE cable or just the terminal end?
Old Sep 2, 2018 | 08:39 AM
Djosbun's Avatar
Djosbun
The sheathing covers the whole cable.
Replace both cables. They will include new ends.
— Dave
Old Sep 2, 2018 | 09:06 AM
xcrsp440's Avatar
xcrsp440
You have a 2 year old rebuilt starter on it now? Use a test light and see if power is getting to the starter My guess is the starter is shot, take it off, get it tested.
Old Sep 2, 2018 | 01:38 PM
seville009's Avatar
seville009
entire cable
Old Sep 2, 2018 | 11:12 PM
burnthelight88's Avatar
burnthelight88
While you're replacing those cables, make sure that you clean the grounding points really well with a wire brush or wire wheel. It should be grounding to clean, bare metal. Rust/paint is no good for grounds.
kolson
2009 - 2014 F150
Nov 14, 2017 12:01 AM
imper
Computer Chips & Tuners
Aug 18, 2014 07:00 PM
Marting
2004 - 2008 F150
Dec 8, 2010 06:49 PM
jdemoNC
Jan 12, 2007 01:39 AM
kkoles2000
Sep 11, 2003 07:55 AM
