Sponsored by: Real Truck
2001 and 2016 Bed Compatible?
Old Aug 28, 2018 | 09:51 PM
nut1605's Avatar
nut1605
I just pulled a tonneau cover off my 2016 F-250. I have a buddy with a 2001 F-350 that could use it. Are the beds compatible? I know there's a whole span of years where the beds are the same or at least close to the same, I just don't remember what those are.
Thanks!
Old Aug 28, 2018 | 10:03 PM
imtrich76's Avatar
imtrich76
The beds are the same from 01 to 16 size wise, the only difference is the body lines above the wheel wells. The cover should fit no problem as long as they are the same length
Old Aug 28, 2018 | 10:05 PM
nut1605's Avatar
nut1605
Awesome, thanks for the info.
Old Aug 29, 2018 | 06:06 AM
Superdave71's Avatar
Superdave71
The top edge of the tailgate is different, not sure when, but I think when the body changed with the 6.4. I bought a used Retrax cover off a 6.0 truck and it fit, but depending on your cover, the problem would be at the top of the tailgate. Some covers seal on the inside edge, some on the top. If yours seals on the inside you should be fine.
stangfan78
2009 - 2014 F150
Mar 16, 2024 01:05 PM
Casey_78
2009 - 2014 F150
Aug 21, 2015 06:32 PM
78bigbronco
Jul 26, 2009 04:25 PM
