2WD Radius arm question
Old Aug 27, 2018 | 10:20 AM
bulldogcountry1's Avatar
bulldogcountry1
In looking through some old threads about caster/camber adjustment of the twin I-beam, someone mentioned removing the rivets from the radius arm mount. The posted said he would add shims to adjust to caster, elongate holes, and replace with bolts.
Well, my mounts already have grade 8 bolts in therm. The truck has been in my family since new (bought by my dad), and it doesn't look like anything has been adjusted. I just wanted to confirm if rivets are supposed to be there from factory.
Old Aug 27, 2018 | 11:33 AM
beartracks's Avatar
beartracks
Rivets are stock. Common practice to drill them out and replace with bolts to replace the bushings. Don't have the info handy but theres a company that makes a cam you install under the spring mount to adjust caster.
Old Aug 27, 2018 | 01:21 PM
bulldogcountry1
I'd like to see that if you can find the info. Since the spring mount is also the radius arm top front mount, I'm guessing that's where the adjustment is built in?
I'd bet the bolts are there because my dad replaced the bushings years ago.
Old Aug 27, 2018 | 02:06 PM
HIO Silver's Avatar
HIO Silver
Caster and camber are built-in. In order to change either, the beams would have to be bent according to Ford's methodology. I would not elongate any holes... that's a bad idea.
The only adjustment is for toe.
Old Aug 27, 2018 | 04:09 PM
beartracks's Avatar
beartracks
https://www.stempf.com/
4410 Camber cams
Can't find them on the site. Might be out of production. Call them. I have a pair but not crazy about letting them go as I only have one installed. You might not need them but they go under the lower spring mount bolt hole after you drill them out larger.
Old Aug 27, 2018 | 06:06 PM
matthewq4b's Avatar
matthewq4b
Ya the correct was to adjust the camber and or caster is to bend the beams.
Old Aug 28, 2018 | 02:26 PM
dogdays's Avatar
dogdays
Thanks for posting the pictures, I don't have my FSM with me and I thought I remembered such a setup.
Speaking of radius arms;
How difficult is replacing the rear pivot bushings?
Thanks,
R.
Old Aug 28, 2018 | 02:37 PM
'65Ford's Avatar
'65Ford
[QUOTE=dogdays;18164451
Thanks,
R.[/QUOTE]
Not particularly difficult. I've replaced the bushings on the back end of the radius arms on a '65 F250 and a '94 F150. I did not touch the rivets on either truck. Support the truck by it's frame on good stands or cribbing. Remove travel limiters and lower the I-beams until the springs can be removed. Then pull I-beams forward until the radius arms can be removed from their frame brackets.
In both cases I also replaced the bushings in the end of each of the I-beams. That was a little harder than the radius arm bushings. I used a drill and hole saw to cut the rubber and remove old bushings. Sawsall to cut and remove outer ring of bushings. And then smoothed the holes in the I-beams with a dremel. Pound in or press in the new bushings.
Old Aug 29, 2018 | 08:17 PM
mofoco1's Avatar
mofoco1
Do not remove or destroy the metal shells in th be radius arm. They are only available as a set pressed in already. Took mine to the machine show where they got th he rubber out and then I installed poly bushings instead. Use poly in the ends as well.
LITTLE BLACK TRUCK
27
Aug 13, 2015 02:30 PM
Tedybear
Feb 18, 2008 06:31 AM
DetailerDave
Jul 17, 2005 07:14 AM
95 slug
May 2, 2004 02:12 AM
FL. Ford
Mar 1, 2004 09:36 PM
