Gas tank
Old Aug 24, 2018 | 01:30 PM
Earn88fan's Avatar
Earn88fan
Gas tank
I have a 77 f100 I ordered a new gas tank without eec vent valve.....after pulling mine out I realized mine had the eec vent....do I have to have it ?....thanks
Old Aug 24, 2018 | 01:38 PM
72rtchallenger's Avatar
72rtchallenger
well it can work but you will need a vented fuel cap and if I remember correctly the two metal lines are reversed from the fuel filler metal lines
Old Aug 24, 2018 | 03:29 PM
Earn88fan's Avatar
Earn88fan
Not sure i understand on reversing the filler lines.....
Old Aug 24, 2018 | 04:23 PM
72rtchallenger
On mine alone I ran into using a gas tank from previous owner install , an he had installed the wrong tank an lines were different but in the long run should be alright running with a vented fuel cap
Old Aug 24, 2018 | 04:54 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Pretty sure he means the metal filler and vent line tank connection (metal to rubber) tubes on the none EEC tank are switched in position versus the filler neck. The pick is a 76 F100 and on a ECC tank the vent line might be fwd of the fill tube? In the pic the vent tube is aft of the fill neck. Make sense? That is what he means by reversed.
Old Aug 24, 2018 | 05:39 PM
72rtchallenger
Exactly what I meant , my 79 F100 had ECC tank originally an filler tank lines reversed when previous owner installed a non ECC tank
Old Aug 24, 2018 | 06:03 PM
Earn88fan's Avatar
Earn88fan
Ol ok on the eec tank (old tank) the small rubber hose is on the left of the main filler tube....on the new tank it's on the right...whitch no problem.....with a vented cap should be ok ???
dotcentral
Ford Truck Parts for Sale
Sep 18, 2012 03:54 PM
ItsAFord55
Mar 5, 2012 03:36 PM
jrodtaclet
Apr 24, 2010 09:19 AM
1964_mezajd
Jan 17, 2007 08:58 PM
Dyerstown
Dec 20, 2003 07:02 PM
