Fuel pump issues
Old Aug 23, 2018 | 04:13 PM
Jonathan Lentzkow's Avatar
Jonathan Lentzkow
5th Gear
Fuel pump issues
I have a 1989 Ford f-150 xlt lariat with a 5.0£. I'm having problems with the rear fuel tank over flowing, a lot of people say it's the dfr anyway I also when I switch it over to the rear tank it acts like it's running out of gas. Which leads my to believe it's also the in tank fuel pump. My question is can I bypass the in tank fuel pump with an external one. My son bought me an eldabrock external fuel pump 38 gph 4-7 psi ( to siphon fuel from the rear to the front tank) would that work to bypass the in tank fuel pump and if it will how would I go about doing it.
Old Aug 24, 2018 | 10:11 PM
DBGrif91's Avatar
DBGrif91
What do you mean by the rear tank over flowing? Is it dumping fuel on the ground when you try to fill up at the pump?
Also, it's probably obvious, but I'm out of touch with abbreviations - what is dfr?
Old Aug 25, 2018 | 04:52 AM
Jonathan Lentzkow
5th Gear
Fuel pump
the fuel feeds back into the rear tank instead of the front tank and when the rear tank gets too full fuel comes out of the rear tank filler tube. The dfr is the duel tank fuel resevar
Old Aug 25, 2018 | 09:06 AM
DBGrif91's Avatar
DBGrif91
Aha - now it makes sense. You're having trouble with an issue that's very common on these trucks. I haven't dealt with it in a while so I can't recall all the details, but you can find the fix for it here -
https://www.ford-trucks.com/forums/2...re-issues.html
Old Aug 26, 2018 | 11:51 AM
BS51993's Avatar
BS51993
I had this on my 88. Ford had a recall for it in the 90s. Auxiliary tank valve was replaced and that solved the problem.
Krisverde
18
Jul 17, 2015 07:47 AM
doublebutted
16
May 9, 2012 04:18 PM
AutoHound
Feb 18, 2009 04:52 AM
firemanshemi
Sep 29, 2007 09:49 AM
frenchf250
Apr 9, 2005 10:50 AM
