removing cats
Old Jul 23, 2001 | 10:06 PM
bsprowl's Avatar
bsprowl
removing cats
Old Aug 14, 2001 | 11:53 PM
htownstunner's Avatar
htownstunner
removing cats
I was wondering if i could remove the cat's off of my 95 with a 351? Could i just cut them off or how could i gut them? There is a pipe from bassani but it says it is an x pipe. I would love if that was what it is but if not a catless y pipe would be fine with me. My dad said something that he heard along time ago that if you ran a tank of leaded gas through it would burn out the cats. Would this mess things up. The whole reason i want to do this is the truck has a 40 series flowmaster and it isn't loud at all. I know this is bad for the enviroment. And i don't have to worry about any emmissions test.
Old Aug 15, 2001 | 04:33 AM
Fordtruxrok's Avatar
Fordtruxrok
removing cats
You could cut the pipe right behind the cats and poke em with something, then start the engins to blow em out, repeat till nothing blows out, Voila finito.
John
Old Aug 15, 2001 | 08:41 PM
restorit's Avatar
restorit
removing cats
Have you considered leaving the cats alone, removing the muffler, and running a larger (2.5" or 3") diameter straight pipe with no muffler? This would keep you legal, and may get you the tone you're looking for. You may never get checked, but it would be a shame to destroy two good cats and then possibly need to replace them someday....
Old Aug 16, 2001 | 02:01 PM
slikness's Avatar
slikness
removing cats
Personally, I would cut the cats out, remove the exhaust manifolds, put on full length headers with true duals (2 1/2") running through two Flowmasters, exiting under the rear bumper. That should give you the sound that you're looking for.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Aug 16, 2001 | 10:53 PM
htownstunner
removing cats
I would do that but i can't bend the pipes. That is what i have really wanted to do all along but i went out to a local muffler guy and he said that he wouldn't do that so i guess there is nothing i can do about it
Old Aug 21, 2001 | 10:47 PM
1988F250's Avatar
1988F250
removing cats
yea i have an 1988 f250 and i have it totally stock! I really wanna put some flowmasters on there, and i have thought about taking the cats off too. Im in texas and i heard that in a couple years they were gonna start doin exauhst tests when they inspect your vehicle. Can anyone help me before i go spend a ##### load of cash when i get my truck dualled? What can i do? thanx in advance!
Old Aug 22, 2001 | 12:06 AM
bobsundance's Avatar
bobsundance
removing cats
I have a 93 F150 I took my exhust off after the y-pipe and put in a 3in pipe with a 3in glass pack. sounds great but dont tell the cops
93 f150 302 with 38s
4.57 gears
Old Aug 22, 2001 | 08:13 AM
RGAZ's Avatar
RGAZ
removing cats
First off, Removing the cat's is totally illegal no matter what state you live in. Its covered under federal law, not state.
Second, why not replce them? I have a new y-pipe and a 3" cat and it really opened-up the exhaust. I ended up putting a big muffler on there to keep it quiet through my neighborhood, but it would definitely be loud as hell if I didn't.
Think about the 3" cat instead.
Randy
Y-pipe is $75 from catco
Cat is $90 from JC Whitney
Other connections are local pieces.
Old Aug 22, 2001 | 08:33 AM
slikness's Avatar
slikness
removing cats
Even though removing cats is illegal by federal regulations, the regulations are policed by local inspectors and not only vary from state to state, but from county to county within the state according to the pollution demands outlined by the state. While the federal regulators inspect the inspectors, they do not penalize them for adhering to the local minimum smog laws.
I'm not sure what the problem is in bending the pipe and making a dual exhaust. I put full length headers on mine and my exhaust guy took 2 1/4" pipe, crossed the driver's side pipe over to the other side (because of my dual gas tanks) under the tail shaft of the tranny into a small cat in each pipe. From there I decided to use the Flowmaster dual in, dual out muffler instead of two mufflers side by side. I came out of the muffler and bent one pipe back over to the driver's side before the rear axle and the exhaust exits under the rear bumper.
Slik
Old Aug 22, 2001 | 08:36 PM
hotrodford_88's Avatar
hotrodford_88
removing cats
Just do what I did, have them put on a single 2 chamber flowmaster, single in dual out, add shorty headers, and a replacement single cat intermediate pipe, also while they are under there, have them add a set of 3.5" exahust tips. (3 inch looks too small, besides every Shecky trucker I've seen has the 3 inch tips. Dare to be different and trust me, mine would set off car alarms! (made many people mad too. Hmmmm, oh well, they needed to reset their sensitivity on their alarms anyway!) You can see how I had mine set up below......
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old Aug 24, 2001 | 12:38 AM
1988F250's Avatar
1988F250
removing cats
[font size="1" color="#FF0000"]LAST EDITED ON 24-Aug-01 AT 01:39 AM (EST)[/font][p]i appreciate your advise... im ready to go do it !! about how much will it set me back ? less than a grand? email to my personal email if u dont mind, kyle? jeffjh04(No Email Addresses In Posts!)
