Please help! Need help identifing a frame.
Old Aug 17, 2018 | 07:47 PM
SNugent09's Avatar
SNugent09
This is my first post, this is my first ford truck actually, let's just say I finally converted from the dark side...... anyhow, I have a 77 F-150 Ranger XLT. I bought the truck, and the guy had a second frame he gave me, gentleman said it was a 75 frame however I am not so sure. Trying to decide weather to use the other frame which has for the most part been restored already, or to restore the somewhat rotted frame the truck currently sits on.
There are a few minor differances between the two frames the most significant differances I can see are that the coil towers for the front have a stud welded on top for the front shock mount where as the 77 frame has a separate shock tower behind the coil tower.
Also the "75" frame has drum brakes up front and a hydrolic steering set up....
one more thing i noticed was that on the "75" frame most everything is riveted together where as the current frame the spring hangers and shock mounts etc.. are all bolted.
Any help would be greatly appreciated. I know pictures will help and I will try and get some tomorrow.
Old Aug 17, 2018 | 08:23 PM
fordguy2100's Avatar
fordguy2100
I can't say for certain and I'm sure more knowledgeable people will be along soon but my guess is all the things that are bolted on the frame and riveted on the other should all be riveted and were replaced/upgraded and the PO used bolts as most people do when they have to cut out the rivets. Again I could be wrong but that's my .02
Old Aug 17, 2018 | 08:42 PM
SNugent09's Avatar
SNugent09
That's kinda what I was thinking as well but I wasn't certain.
Old Aug 17, 2018 | 08:48 PM
flowney's Avatar
flowney
Look for the VIN on each frame then decode them. This will tell you what the frames were for and whether they are likely compatible with one another. Agree with fordguy2100 re bolts in place of rivets. Assuming compatibility with cab, bed, etc. it sounds like this is the frame you want to use.
Old Aug 17, 2018 | 08:58 PM
SNugent09's Avatar
SNugent09
where do I find the VIN for the frame?
Old Aug 17, 2018 | 09:03 PM
flowney's Avatar
flowney
It will be on the top frame rail of the passenger side in two places. Right under where the alternator on a V8 would be and the other right under the passenger's butt. Vigorous wire brushing should reveal them.
Find the VIN decoder under Tools in the black menu bar for this site.
Old Aug 17, 2018 | 09:30 PM
fordguy2100
You will see this picture all over FTE. Save it lol
Old Aug 17, 2018 | 10:28 PM
SNugent09's Avatar
SNugent09
Thank you guys for all the help. I will be out looking for the VIN tomorrow, I'll advise on what I find!
Old Aug 18, 2018 | 09:19 AM
4x4slik's Avatar
4x4slik
Need to read the text in that picture. The engine compartment one is in different locations depending on 2wd or 4wd.
Old Aug 19, 2018 | 02:25 AM
1TonBasecamp's Avatar
1TonBasecamp
And I don't know about all years and all models, but I would use caution when trying to uncover a buried frame VIN. They're so shallow sometimes that getting too aggressive with the sandpaper or scraper or wire wheel might rub it off!
Paul
Old Aug 19, 2018 | 08:36 AM
SNugent09's Avatar
SNugent09
Paul
yeah so I was doing some looking around this morning and I fear whoever restored this extra frame I have might have grinded the vin off mistakenly.... i did find a few numbers along with what looks like a star, so I'm going to try and carefully get the paint off so i can read what's left.
Old Aug 19, 2018 | 12:20 PM
wyrm73's Avatar
wyrm73
Yup, you're in the right area. The star is the beginning of the VIN. My wife's 65 was the same way- first few digits were pretty solid, but the last 4 or 5 were REALLY hard to read. I had an advantage in that I was trying to compare it to a known VIN off the title. Yours will be more of a challenge. As has already been said, work slow or you could grind it off completely.
Old Aug 19, 2018 | 05:26 PM
SNugent09's Avatar
SNugent09
how many digits should I be looking for?
Old Aug 19, 2018 | 05:42 PM
1TonBasecamp
Probably the same number as are in your other, registered truck.
My '79 still gives the DMV fits because the actual string of numbers at the end of the VIN are only 4 digits long. The whole thing is only 11 digits long, letters and numbers combined.
Paul
Old Aug 19, 2018 | 08:38 PM
wyrm73's Avatar
wyrm73
Yes, 11 digits total. Just to expand on what Paul wrote- 73-77 used 1 letter and then 5 numbers. 78 & 79 used 2 letters and 4 numbers If your frame really is a 1975, the letter should be a V, W, or X.
