Disc brakes needed? Pics...
#31
Bill, if you can swing it, I would strongly consider heading to MorRyde and have them do their IS conversion along with disc conversion at the same time. For me, the IS was more important than the discs. I had the Equaflex equalizers between my axles and I replaced one after finding it cracked and ready to fail after year two. When at MorRyde I went through the pile they took off and found two more with cracks starting. Now I have a very HD better riding suspension under my rig and discs to boot. It was a huge improvement all around so if you intend to keep your RV long term, I wouldn't hesitate. If you are interested and need any specifics, shoot me a PM. It was an great trip. MorRyde lets you stay in your RV overnight each night so no hotel needed. Then you can tour RV country all day. RV hall of fame. Stop into your brands plant for a factory tour. Etc.
PS: My trip to MorRyde starts on this page of my thread. Lots of other BS in there but some good pics of the R&R...
https://www.ford-trucks.com/forums/1...e-day-713.html
#32
Your magnets should have 4 dots opposite each other. I only see one that usually indicates that the magnets are getting close to replacement time. Have you manually adjusted the brakes? I have the same brakes and can lock them up running on the 8 setting. Therefore I run on #7.
#33
I have my brake kit, and have an install question. Would you run the steel lines from the actuator to the axle on the bottom of the frame rail, outside of the belly pan, or inside the belly pan? I figure the trailer has tons of ground clearance in the front, so no risk there. The lines are dryer inside the belly pan, but harder to inspect. Thoughts?
#34
Received 6,693 Likes
on
#35
I ran mine on the outside of the frame until I got past the holding tanks them went to the inside. I didn't want then in the wheel well area because of possible damage from a blowen tire plus you have to cross over to the other side anyway.
If any of your lines are to long just make a coil out of the excess, don't try to cut and flare them unless you are really good at making a double flare.
Denny
Denny
#36
I love the disk brakes put on by Performance Brake. At last I can get our 5th wheel to stop quickly. I had a nice test when on Hwy 199 in California. I was going around a tight curve when we came across a rock slide covering a good portion of my lane. Yip. I'm sold on being able to stop quickly. I also moved up to a SRE4000 suspension and 17.5" wheels. Now I run H rated Sailun tires. Nice combination. After our 9200 mile trip this summer, I am very happy with the whole package and love the F450 pulling it.
#37
#38
#39
When I bought my 2018 Bighorn Traveler I was given specific instructions from the dealer on how to break in the brakes. It was my first trailer so I was woried about other things (like getting it home safely having never towed). I called the dealer and explained that even on highest gain that I was not feeling anything using the manual brake controller. To make a long story short the dealer insisted that I follow there procedure and if that did not work they would look at it. I followed their procedure to a T and I am now setting on the mid setting and a 5.5 gain. If I hit the manual control I can stop with just the trailer. I have the Never adjust brakes.
#41
I'd love to go to disc brakes but here in the UK we have to have a mechanical parking brake on at least one axle. I've already done a conversion using dexter brake assemblies which is ok, but as I'm close to GCWR with this trailer the extra braking from discs would be great so. ........is there a disc system that has a park brake facility? Doesn't matter if it's like our trucks (drum in hub) or GM style winder on caliper piston.
#42
Denny
#43
Wouldn't be all that hard because it's not like a master cylinder it's a pump so a normaly closed solenoid in the brake line coming off tbe pump. Power the soleoid when trailer is in use and energize the brakes and take the power off the solenoid and the brakes would be locked.
Denny
Denny
#44
I had the installer recommended by Performance Trailer Braking, "A A Mobile Services" install my brake kit. They made the three hour drive and installed the brakes at my house. From arrival to test drive only took four hours. They said that they have installed almost 600 of these kits, so they were very efficient. I'll post a review with pictures after my next trip. On the test drive, I could easily lock the brakes with my controller on 7, something I could never do even at 10 with my old brakes.
#45
