Show me your magnetic gray Super Duty
#61
#63
Nice truck.
#65
Please share specs on lift, offset, rub, tires... I thought I was 100% ready to order 20s until I saw this...
#67
Haven't posted anything here in a long time (been pretty quiet since way back when I was all-in on my Excursion build), but this thread caught my eye... Here's my 2017 Lariat Ultimate:
Bumpers and Grille painted, 2.5" Ready Lift and 295/65R20 Nittos. Pretty happy with it except all the rake is gone, probably because my truck had the plow-prep front springs. Thinking of switching to Carli springs and shocks in the future...
#68
Truck has 3.5 inches of lift in the front and zero lift in the back. I did a tasteful trim on the rear of the front fenders as well as the 2wd front valance. Zero rubbing. Ill take some closeup pics this evening.
#make37sgreatagain I hate low profile offroad tires.....
EDIT--PICS added. Also, the 3 link arms are not necessary, I just hate the look of the radius arm drop brackets....
#69
#70
#71
37-13.50-17 Toyo MT on 17X9 wheels with a -12 offset.
2. What is your caster set to? Any bump steer?
3. What 3.5" lift did you start with?
4. Adjustable track bar or trackbar relocation bracket?
5. What wheels are those?
#72
#73
1. Are those PMF 3 link arms? Yes
2. What is your caster set to? Any bump steer? just a hair under 5*, yes it has a tiny bit, but I plan for it to go away when I go back to a OEM trac bar bracket and Carli bar
3. What 3.5" lift did you start with? 3.5 ready lift, but plan to switch to a 4" spring.
4. Adjustable track bar or trackbar relocation bracket? Ready lift bracket, but plan to order the carli trac bar and re-install the OEM bracket
