Sponsored by: Auxito
Malfunctioning Taillamps
Old Aug 9, 2018 | 04:41 AM
Charles Thompson's Avatar
Charles Thompson
When I signal to turn all my lights head,signals,third brake,and plate lights flash as if I turned on my hazards,when I turn on my Headlamps none of the lights in the rear work....
I've replaced the wire connectors and sockets in my tail lights, replaced my multi function headlight switch ,I've checked fuses and replaced all bulbs....
Anyone have a idea on what the issue is
Old Aug 9, 2018 | 09:07 AM
projectSHO89's Avatar
projectSHO89
You have an open ground circuit. There's nothing wrong with any of the bulbs, switches, fuses, sockets, connectors, wiring,etc.
Start by removing the kick panels on both sides of the cabin and inspecting the grounding studs for loose or corroded connections.
If that doesn't solve the problem, post back and this time, explicitly identify your truck. We're not psychic and there are variations over the years.
6fifty_f1fifty
Apr 4, 2012 10:11 AM
Wicked Endings
May 11, 2010 02:13 PM
slntnddly
Electrical Systems/Wiring
Oct 30, 2004 03:46 PM
Meilichios
Jan 19, 2004 08:52 AM
derek_seli
Jun 14, 2003 04:56 PM
