Hey everyone I have a problem my 85 f250 351w will crank but won’t fire I have been told if the crankshaft sensor is out that it won’t? I guess my question is if this is true and a possible location?
I don't know everything but I don't think it has a crank sensor.
I take it you don't have spark and why it was thought crank sensor.
I hope the person that told you that does not fix cars for a living.
Dose your dist. have vacuum line to it or just wires going into a small box?
Maybe post up a picture of your dist. so we can see what you got.
As a guess if you have that small box with wires going into it known as a TFI module could be bad.
Or if you have a vacuum line to the dist. the IGN. module on the inner fender is bad.
Dave ----
You are right that box off the side with the wires going to it is the TFI (thin film ign) They are cheap enough I would replace it and if that is not it you have a spare in the glove box.
The only other thing I can think it could be is the pick up coil, think its called PIP forget what it stands for, inside the dist.
Dave ----
