2019 Super Duties with B&O Play
#46
I too am waiting on a driver's door speaker. Blown since new. Current ETA is January some time.......:-(
#47
Best of luck!
jim / crewzer
#48
#49
About 200 miles on my new 19. I think the stock system that was in my 07 F150 CC sounded better. Clearer, Crisper.
Ive messed with the audio settings the best I could with the B&O, just doesnt sound right to me. Needs something....
Maybe its because its a bigger truck, different speaker placements... I dont know but it diffidently needs some thing.
I did notice too that listening to SatRadio sounds differently then just some of the local stations.
#51
I don't think it sounds bad at all. Just in the two weeks I've had it, the bass response seems to have improved. HD radio sounds great, iPod sounds excellent, streaming is okay and Sirius is typically horrible. I had the standard system in my 2016 F150 Lariat. Swapped out the door speakers and I added an amp and sub. Was it cleaner at high volume? Yes. Way better bass response? Yes. Do I feel a need to do the same to this B&O system? Nope....at least not yet. Yesterday, I switched from the stereo setting to surround. So far I think it's an improvement. Definitely more immersive.
#53
#54
Had a RAM 2500 - Audio system was great, motor was great, everything else was a nightmare.
Only issue with the F250, and my 17 GT 350 - the audio system,
I did the JL Audio C2's front and back with some dynamat padding and the Dayton center channel speaker. Removed the Sony Sub and packed the case full with polyfill from Michaels
Here is a link to what I did.
https://www.ford-trucks.com/forums/showpost.php?p=17984024&postcount=42
https://www.ford-trucks.com/forums/1536690-kicker-upgraded-speakers-sub-3.html#post17984024
walk thru the thread - you'll see the Dayton center channel speaker. It's important to pay attention to the speaker impeadence whcih may be different on the B&O
#56
Dropped right in. I used 3M double sided tape to mount it. I also used a soldering gun to remove the wires / clip from the old speaker - moving it to the new speaker.
Plug and play.
Have had no issues.
#58
FYI - let the speakers run for 20 to 40 hours - they will break in and sound better. Saw this first hand both on our F250 and our GT 350.
#59
jeep wrangler
My 2017 wrangler with the alpine subwoofer system rocks, It has good quality highs and the base is solid and just keeps getting louder as the button turns, at 56 it works for me.
#60
