Can't keep motor running
Old Aug 7, 2018 | 10:38 AM
Tthomas79's Avatar
Tthomas79
I recently bought a 79 f350, 351m c6 trans. When I bought it we knew it didnt run the guy swore up and down it was just a bad carb, after seeing how bad it looked it made sense. Since then I have rebuilt the carb, replaced spark plugs, wires, cap and rotor, fuel pump, new rear fuel tank with all new fuel lines. New ICM, new voltage regulator, battery, and alternator. The truck start right away but does after about 6 seconds, every now and then it'll start and stay running for a while to the point where I feel like it'll make it around the block. It makes it about 4 houses down then dies again. We've tried adjusting the carb and still no progress. Hoping someone has a recommendation for what to look for next, at this point anything will help!
Old Aug 7, 2018 | 12:54 PM
FuzzFace2's Avatar
FuzzFace2
When it dies is the motor getting gas and have spark?
We need more information before we can try and help.
Dave - - - -
Old Aug 7, 2018 | 05:57 PM
flatbedfordguy's Avatar
flatbedfordguy
You have pretty much thrown the whole parts store at the problem lol......my best guess would be a vacuum leak.
Old Aug 8, 2018 | 07:42 PM
BigMightySam5600's Avatar
BigMightySam5600
Magnetic pickup coil use only morotcraft replacement part.
Old Aug 8, 2018 | 08:12 PM
Tthomas79's Avatar
Tthomas79
We replaced the distributor last night and got it all timed and drove it around the block a few times and then into the garage. This morning after I changed the oil went to go to the gas station to fill it up and made it only a couple houses down before it started cutting out. It will halfway idle on it's own, but the second I'd give it gas Itd sputter and die. I'm starting to think this thing is cursed, going to look into a new carburetor, any recommendations? Right now it's just the stock motorcraft 2 barrel 2150.
Old Aug 8, 2018 | 08:39 PM
User 32921's Avatar
User 32921
I've heard of similar issues being related to a bad ground or electrical connection that LOOKED good but wasn't crimped well or corroded.. come to think of it– I've experienced that myself!
Old Aug 8, 2018 | 08:45 PM
Tthomas79's Avatar
Tthomas79
Yeah some of these wires definitely need cleaned up
Old Aug 8, 2018 | 08:52 PM
LiveFrom1977f150's Avatar
LiveFrom1977f150
In general when ive had spark issues in trucks their was lots of misfiring but the motor still ran. When it was fuel related the motor doesnt run at all or cuts out due to shortage. Just my experiences. I could absolutely see this being carb related.
Old Aug 8, 2018 | 08:58 PM
Tthomas79's Avatar
Tthomas79
I went through 2 cans of starter fluid and sprayed every inch of that motor and the idle never changed
Old Aug 8, 2018 | 10:56 PM
meangreen92's Avatar
meangreen92
What about the Duraspark ignition box?
Old Aug 8, 2018 | 10:59 PM
Leebus's Avatar
Leebus
I didnt see anything about a fuel filter did you change that? Sounds like a fuel problem to me. Run some checks and slow down on the parts. Check your spark color, timing, etc.
cheap to check.
Old Aug 9, 2018 | 05:03 AM
Tthomas79's Avatar
Tthomas79
Replaced that
Old Aug 9, 2018 | 05:06 AM
Tthomas79's Avatar
Tthomas79
cheap to check.
The guy I bought the truck from removed both tanks and just used some random tank behind the seat. So I got a new tank all new lines and pump and already put a new filter in.
Old Aug 9, 2018 | 12:18 PM
Leebus's Avatar
Leebus
ok , I suspicious of that carburetor. Also what about the coil? Have you checked that?
Old Aug 9, 2018 | 12:48 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Agreed. If you've eliminated vacuum leaks, PCV, fuel delivery, and ignition problems, I'd try another carburetor. But of course that's the first thing I do anyway since there are much better carburetors and intake manifolds available than Motorcraft
