F350 SRW CC - Cargo Capacity #3063 & #3090
Old 08-12-2018, 12:35 AM
Flyct's Avatar
Flyct
Flyct is offline
Originally Posted by rtraviator
Thanks for the photos looks like the cab gets pretty darn close. The torque and torsion on the tires is incredible, hopefully the tires are taking the brunt of this.
I still went with a Short Bed on my new ordered truck because of the following;
The Long Bed payload is about 250 lbs less than short bed
Turning Radius is 5 feet more with a long bed
I would be over gross on payload with a long bed towing my 337RLS
I went with the Andersen hitch initially because of the 200#s of weight savings over a conventional 5th wheel hitch. I love the hitch. I can take it out in less than 5 minutes and lift it out with one hand. It hangs on the garage wall when not in the truck bed.
This combination gives me more than enough turning angle. I never want to go over 45-50 degrees due to the stress on the trailer suspension. I can easily see the cap/cab clearance in the back window and/or rear view mirrors.
Here’s another view of max turn.
Old 08-13-2018, 10:56 AM
rtraviator's Avatar
rtraviator
rtraviator is offline
That’s a relatively tight turn. From the angle it doesn’t look like the truck is squatting at all.
Old 08-13-2018, 11:29 AM
Flyct's Avatar
Flyct
Flyct is offline
It’s deceiving. I measured the truck squat. It squats 3” once the Reflection is hitched.
Old 08-13-2018, 12:18 PM
mrgrayaz's Avatar
mrgrayaz
mrgrayaz is offline
3000lbs in the bed the truck will be nicely level - definately drops the rear 2-3". We are running a slightly heavier trailer (16200lbs) and its a nicely handling machine with no truck modifications whatsoever between 6800-7000lbs RAW, about 25k combined. I laugh at the "you gotta have airbags" crowd. Run it within spec, and there is zero need for modification on a F-350.
Those 90deg turns are tough on the trailer suspension - I do them regularly as we move every several weeks, and so far have torn/ripped two spring shackles. Not a huge deal, but something to be aware of.
Old 08-13-2018, 02:00 PM
scraprat's Avatar
scraprat
scraprat is online now
Received 2,502 Likes on 1,307 Posts
What spring shackles or suspension system on the Alfa?
Old 08-13-2018, 02:25 PM
mrgrayaz's Avatar
mrgrayaz
mrgrayaz is offline
​​​​​​​Standard tandem leaf spring arrangement - no IS or MorRyde here. They do offer a HD shackle upgrade
on Amazon on Amazon
- unfortunately last time I needed a repair I couldn't get it in time, so got to replace all my shackles with new....standard strength ones doh!
Old 08-13-2018, 03:00 PM
scraprat's Avatar
scraprat
I was thinking that the Alfa would of had MorRyde LRE suspension systems under it for some reason. Even though you changed out the shackles already and there're probably still new its worth doing the upgrade night & day difference in the quality/ thickness and being able to grease them doesn't hurt either.
Old 08-13-2018, 04:28 PM
mrgrayaz's Avatar
mrgrayaz
mrgrayaz is offline
Its a heavy duty high end unit, but its 14 years old at this point. I don't know if the MorRyde LRE even existed back then. It certainly wasn't something I knew about to look for when we were shopping (like so many things...hah).
Old 08-13-2018, 05:10 PM
scraprat's Avatar
scraprat
They where around it was on my '05' Cameo. But I know what you mean knowing what to look for everything is a trade off and having these boards help new comers that are putting their toe in the water.
Some are realizing the bones of the rig are more important than the bling. Pigs with lipstick don't look so well after sobering the next day.
Old 08-15-2018, 11:30 AM
rtraviator's Avatar
rtraviator
Originally Posted by Flyct
My 2017 Lariat Short Bed F350 has a payload of exactly 3500 lbs.
So I’ve found a 2018 F350 very similar to yours. It has a CC of 3417. What is your opinion, any problems, safety issues...? The Anderson Ultimate is 35 pounds, the wife and I are 380 and if I use your 2800#, still puts me less than 3417. This particular vehicle doesn’t have the 5th wheel hitch prep, so an additional computation will be required.
Thanks,
Tony
Old 08-15-2018, 11:59 AM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
Thanks,
Tony
did you look at the door certs, what was the FAWR and RAWR? What were the tire ratings on the side wall of the truck?
Old 08-15-2018, 12:26 PM
Flyct's Avatar
Flyct
Flyct is offline
Thanks,
Tony
You should be fine with that truck with an Andersen hitch and a Reflection 337. . Not a problem without the OEM 5th wheel hitch. Just have the Trailer dealer install a B&W 5th kit. https://www.etrailer.com/g-2018_Ford...Rail+Kit&furl= They install these all the time.
My 2800#s pin weight is with lots of stuff loaded in the trailer pass through storage.
If you are buying a new Ford make sure you take advantage of the $3000 PCO.
  #28
Old 08-15-2018, 12:28 PM
rtraviator's Avatar
rtraviator
FGAWR = 5990#, RGAWR = 7230# Did not look at tire ratings. According to the window sticker it has the LT275/65R20’s unknown brand at this point.
  #29
Old 08-15-2018, 12:31 PM
Flyct's Avatar
Flyct
Flyct is offline
Here is my weight sheet from Grand Design as delivered from the factory.
  #30
Old 08-15-2018, 12:41 PM
rtraviator's Avatar
rtraviator
Interesting 2019 337RLS states
Grand Design Reflection 337 - UVW 10,570
Hitch 2090
GVRW 13,995
Quick Reply: F350 SRW CC - Cargo Capacity #3063 & #3090
