Engine swap this weekend, advice pls
Old Oct 2, 2003 | 11:18 PM
billyjoe's Avatar
billyjoe
Yes the C4 trans flexplate fit perfectly. The kickdown rod must be out of adjustment a bit because there is a buzzing noise coming from the trans and when I wiggle the kickdown linkage it stops temporarily. Guess my first drive will be to a trans shop.
Old Oct 3, 2003 | 07:27 AM
jwtaylor's Avatar
jwtaylor
Well glad it fired up and everything bolted up, good luck with the trans
