inline 6 blowing oil everywhere
Old Sep 22, 2003 | 08:27 PM
melted1's Avatar
melted1
Unhappy inline 6 blowing oil everywhere
I have an inline 6 (1994) and the thing started blowing oil when it runs ... all over. Can someone help with a suggestion for repairs? The exaust is clean, the oil level seems to be ok and the pvc valve rattles.
Old Sep 23, 2003 | 12:23 AM
castman's Avatar
castman
Hey melted1,
Welcome to FTE! I've been experiencing the same problem, and what I've found out so far is that this is pretty common in this engine as they accumulate the mileage. The rings begin to allow a little "blow-by" from the combustion chamber into the crankcase and pressurize it. When the pressurization becomes to much for the PCV to bleed off, it starts blowing out the PCV breather tube into the air cleaner, the dipstick tube, anywhere it can get out. And because the oil it carries out is either vaporized or carried out as a real fine mist under pressure, it makes a HUGE mess with a pretty small amount of oil!
Open your air cleaner to see if it is full of oil. Check your dipstick to see if it is backed out about a quarter or a half an inch. I'm likely going to have to rebuild my engine soon, but in the mean time I pulled the breather tube off of the air cleaner and routed it to a little container with a filter. The oil collects there and the engine compartment stays cleaner. And I just don't put many miles on my truck, so it may go this way until late spring. (When the weather starts getting nice again. At this date, I probably have only a couple weeks left before the drizzle sets in forthe winter.) I just can't overhaul it right now.
There are some other possible causes, but this sounds pretty common from what I've read on the forum. Also, you might try posting to the inline 6 forum if you haven't already. The guys who post a lot there seem pretty helpful.
Good Luck.
Old Sep 23, 2003 | 07:11 PM
melted1's Avatar
melted1
in your opinion, if all the breathing items are ok, is it time for ring job?
Old Sep 23, 2003 | 08:28 PM
castman's Avatar
castman
Actually, if everything else is checking out okay, it is time to check the compression or have someone check the compression for you. The results of the compression test will tell you whether you need an overhaul or not. It wouldn't surprise me if that's where you're at, but its important to base your decisions on your test results rather than my opinion
Also, I'm only a few weeks ahead of you here and can only relate what my experience has been so far. I'm going to encourage you to seek out more experienced opinions than mine. How 'bout it guys; somebody else chime in on this?
Old Sep 27, 2003 | 06:44 AM
Madsan's Avatar
Madsan
I have the same problem and posted here. Also took it to a garage and was told I needed to rebuild or replace the engine. Here is my post on the subject. You can look through this post it has many good responses.
https://www.ford-trucks.com/forums/s...hreadid=150295
Old Oct 5, 2003 | 08:44 PM
melted1's Avatar
melted1
found problem....
5 broken rings
Thanks for the help
