Yes it would. Pretty random issue I have too. The ac has always worked good and then just stopped one day. About a week later on the way home from work it started working good again. Nice and cold and worked great for about two weeks and then all of a sudden stopped working again last week. I am guessing it is an electrical issue but could be not fun to track it down.
No codes at all Troy? That's first thing I would check. Then when it is blowing warm, see if the compressor stopped running. If so, look at the data and see if a pressure switch is reading low pressure or the evap temp is off. Those are about the only things not wiring related that could cause it to come and go.
I will be honest Dave I never thought to check for codes. I will have to hook it up when I get home and see what it says and check those things. Thanks!
