Axle Assemblies??
Old Jul 31, 2018 | 07:07 PM
Wilmax's Avatar
Wilmax
Axle Assemblies??
Is the SRW F350 with 4WD have the same axle assemblies as the Excursion 4WD vehicles do? I'm looking at a 2004 F350 4WD SRW that I'm told has 4.56 gears. If so is it an exact swap situation? I would love to have those gears in my Excursion but will only try it if they're the same. Thanks, Max
Old Jul 31, 2018 | 08:19 PM
pirate4x4_camo's Avatar
pirate4x4_camo
The 04 F trucks have a sterling 10.5 in the rear and a Dana 60 up front
your Ex has a 10.5 and a Dana 50
the 10.5 is compatible but the 50 uses a smaller ring gear so you can not use just the gear, . the whole Dana 60 will work if you shorthen the front drive shaft a bit.
Old Jul 31, 2018 | 09:35 PM
Wilmax's Avatar
Wilmax
Thanks Pirate, just what I was hoping to hear. Max
Old Jul 31, 2018 | 09:49 PM
harley4jcs's Avatar
harley4jcs
Did you read his post correctly ???
Old Aug 1, 2018 | 05:34 AM
WE3ZS's Avatar
WE3ZS
If that F-350 is being parted out take it's front driveshaft. And be sure to make sure that they are in fact 4.56 gears before you start the work!
What engine and what size tire's does your EX have?
Old Aug 1, 2018 | 06:06 PM
loganj01's Avatar
loganj01
Following because I traded for a 99' F350 SRW earlier and was thinking about pulling the front end on it and doing gears, bearings, seals, u joints, ect... and putting it under my Ex instead of doing the existing one a piece at a time.
Old Aug 2, 2018 | 08:31 PM
Misky6.0's Avatar
Misky6.0
The 99 f350 has identical axles to all excursions. The driveshaft are diff for each engine though
Old Aug 2, 2018 | 08:46 PM
pirate4x4_camo
IIRC the new super dudy F trucks didn’t get front 60’s until early 2001
Old Aug 2, 2018 | 08:55 PM
pirate4x4_camo
Easiest way to identify them at a glance.
Kai Herrmann
Jul 26, 2018 09:26 AM
big boy toys f250
Nov 23, 2012 09:43 AM
F-22
Nov 1, 2004 12:26 AM
lisagoud
Oct 31, 2004 09:39 PM
bushman
Jun 27, 2003 04:48 PM
