2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
03 expedition 4.6 intermittent miss
Old 07-31-2018, 01:16 PM
All4ford5.4's Avatar
All4ford5.4
All4ford5.4 is offline
I've searched forums and unfortunately i've not found a direction to go.. 160k on the odometer. New motorcraft plugs and recently new coils (accel) which i use in my truck and LOVE them. Anyhow, usually once per drive cycle I get a dead miss for maybe 20 seconds and then clears up and runs great. The only blame code i get is p0300. sometimes no codes. Im certain its only one cyl going down but i lose tremendous power when it happens. No noise from cats, and besides it runs too good typically to be a cat issue (i think). Never any lean codes or any other clues. Im beating my brains out here. This truck has done this since i bought it. 10000 miles. Any issues with valves sticking on these engines?
Old 08-01-2018, 08:03 AM
alloro's Avatar
alloro
alloro is online now
Received 4,242 Likes on 2,473 Posts
Could be the EGR valve sticking.
Old 08-01-2018, 02:39 PM
All4ford5.4
that's a thought... maybe I'll eventually get an egr code!
Old 08-08-2018, 07:55 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
There should be misfire counts in mode 6 data. That will require a scanner to access a code reader cant do it. Also look for coolant around #5 these have a tendency to crack the intake under the aluminum coolant tube where the thermostat bolts. If you still have the factory coolant there may be white crusty deposits in the area. That is the factory stop-leak.
Ensign Pulver
6.4L Power Stroke Diesel
01-05-2015 08:03 PM
wresleu
1983 - 2012 Ranger & B-Series
10-21-2013 09:03 AM
Navigating180k
1997-2006 Expedition & Navigator
03-24-2013 12:21 PM
kyman42_2006
1997 - 2003 F150
06-10-2006 02:35 PM
jinx102672
07-25-2005 07:57 AM
Quick Reply: 03 expedition 4.6 intermittent miss
