Tach and safe light....
The safe light goes out and tach operates when the engine rpm's are at 1200. I haven't hooked it up to the code reader yet, any ideas before I go to that expense? All fluids are new and and full..not over full. New throttle position sencor with updates was installed recently as well as a new injector pump and the truck runs like new at 203,000 miles, this is the only problem.
To check RPM sensor:
1. Remove 2-wire connector end.
2. Hook DVOM meter leads to sensor pins. Doesn't matter which way.
3. Set scale to AC voltage, 0 to 40 voltage scale.
4. Start engine in park. Raise RPM while watching DVOM.
5. Voltage must increase or sensor is bad.
R.A.
