Sponsored by: Real Truck
Help fixing air gap
Old Jul 30, 2018 | 01:29 PM
dx3's Avatar
dx3
Help fixing air gap
2005 F350 DRW
I am having air gap issues with my truck. Got underneath and verified I’m at about 0.65. Truck blows cold for about 5 mins and then warm.
I found a cool website with instructions on how to fix it, and being a rookie mechanic I ran into an immediate issue. The directions say to turn the ignition on without starting truck with the AC on, and this will pull the plate in so I can remove the 8mm nut. For some reason I can’t get it to engage so it just spins the compressor pulley. What am I doing wrong here?
I hd a guy rig it with a zip tie last week when it was 113 out, but it didn’t hold so now trying to fix it myself. He confirmed it was an air gap issue. So if it does get cold to begin with then wouldn’t that mean the plate is being pulled in? What do I do now?? I’d like to learn more about my truck so I don’t have to run to a professional every time I have an issue.
Thank you,
Old Jul 30, 2018 | 03:45 PM
TooManyToys.'s Avatar
TooManyToys.
Don’t know about that internet trick, but when I did mine I used a flat bar similar to a file to hold the plate while I unfastened and fastened the bolt while adjusting the gap.
Example for when tightening.
Old Jul 30, 2018 | 09:19 PM
dx3's Avatar
dx3
Thank you sir. I’ll give that a shot. There’s not much room up there for an adult hand. I could barely get the ratchet in there.
Old Jul 30, 2018 | 09:57 PM
TooManyToys.
If you have a long square shanked flat screwdriver it can work. I think I have some 1/2" square stock at one point. Yeah, not much room.
Old Jul 31, 2018 | 06:18 AM
projectSHO89's Avatar
projectSHO89
Generally, that doesn't work on the newer PCM-controlled clutch systems. If the engine isn't running and all other operational conditions satisfied, the PCM won't command the clutch to engage.
You can buy a tool at your local parts store that's made for the job of holding the plate, but I usually just use a screwdriver as was suggested previously.
Old Aug 3, 2018 | 10:09 PM
dx3's Avatar
dx3
Thank you gentlemen for your help. I will try to get under there and get it fixed. This heat is too much to ha Dee without AC!
rc.chris
Dec 15, 2018 01:09 PM
Gwilkrrs
Dec 11, 2018 05:34 PM
superdutyinwyo
Oct 27, 2018 05:17 PM
Gianni
Aug 17, 2018 09:45 PM
dx3
Jul 14, 2018 10:17 AM
