Radius Arm Bushings
Old Aug 27, 2001 | 03:09 PM
Skottt's Avatar
Skottt
Radius Arm Bushings
I have a 1995 F150 4x4. How hard is it to replace the radius arm bushings? I have a 4 inch suspension lift on it so there is a spacer in between the frame and bracket of the radius arm. If I lift the front end off the ground, can I then unbolt the bracket from the frame?
Thanks,
Scott
Old Aug 29, 2001 | 09:06 AM
Fordtruxrok's Avatar
Fordtruxrok
Radius Arm Bushings
Getting it all apart is easy, but getting it all lined up and putting it back together can be tricky. Just make sure you put the bushing in the bracket, and not the radius arm when you put it back together.
John
Old Aug 29, 2001 | 11:49 AM
GmanPride45's Avatar
GmanPride45
Radius Arm Bushings
