Sponsored by: Auxito
Fuel pump issue (maybe)
Old Jul 28, 2018 | 11:46 PM
HillBillyBuddha's Avatar
HillBillyBuddha
My 1998 F150 4.6l will run well in the morning and the evening. If I run it during the heat of the day, it acts like it's running out of fuel and then die. And then won't turn back on until the evening. I was hunting for vacuum leaks and anything I could think of but nothing made it better. Then I noticed when I tried to turn it on, after having sat for awhile, I wouldn't hear the fuel pump prime. So i listened a few times. Every time it wouldn't start, i wouldn't hear the pump prime and every time it would start, i could hear the pump prime. I replaced the fuel pump relay but that didn't help.
So a couple questions. Before i replace the pump I want to make sure power is getting to it. I pulled the bed and there are four wires going into the pump. Looks like a pink/yellow, pink/black, dark blue, and a yellow. Which one of these wires will be live when I put the ignition switch into the on position? And will the wire stay live in the on position or will it only be powered long enough to prime the fuel system?
thanks
Old Jul 29, 2018 | 06:39 AM
projectSHO89's Avatar
projectSHO89
Pink/black is pump power, black is ground. The other two wires are for the fuel level sender circuit.
You should have battery voltage for only about 2 seconds when you first turn the ignition switch from OFF to RUN, then it will drop to some random voltage from 3-8 volts.
Old Jul 29, 2018 | 11:43 AM
Chad T. Keogh's Avatar
Chad T. Keogh
Sounds like the exact same thing that happened when my fuel pump bit the dust. Replace the fuel filter at the same time, because it will be filled with pump schrapnel from the failure.
Old Jul 30, 2018 | 09:13 AM
alloro's Avatar
alloro
Test the fuel pressure during the times it won't start. Also, does the tank being full or empty have any affect on it starting or not when hot?
Old Jul 30, 2018 | 10:31 AM
HillBillyBuddha
I tried to test the power going into the pump yesterday but it was oddly cool out. It has been 102 to 109 everyday for the last few weeks but yesterday was in the 80's so the truck (for the first time in a few weeks) did not stall. I already had the bed off so I went ahead and changed the pump and filter. I did notice that the fuel coming out of the fillet was black as oil. Anyway, i'll get to 100 today so I shouldl know for sure today.
Old Jul 31, 2018 | 03:59 PM
Aftrmidnite's Avatar
Aftrmidnite
Sounds like what happened with my Fuel Pump, it had a dead spot on the armature, and would get stuck. Plan on replacing the Fuel Filler hose at the same time.
idlewild
1983 - 2012 Ranger & B-Series
Aug 10, 2015 03:10 PM
Prez
1997 - 2003 F150
Apr 21, 2015 09:49 PM
MFP8055
Feb 1, 2011 11:41 AM
ccmeigs
Oct 31, 2010 04:47 AM
FreeFall
17
Dec 22, 2006 10:07 PM
