Tail end
Old Jul 28, 2018 | 11:34 AM
Hotrod350's Avatar
Hotrod350
Tail end
Thanks to Dave (df85732) I have figured out that I am missing a part of my frame. The part I am missing is pictured below. It extends 8 1/2 inches from the end and is part of the spare tire carrier. It looks to fit inside the end of the frame as an extension.
Does anyone know what this is called?
Where I can find one?
Have a technical drawing so I can get a reproduction?
missing
Old Jul 28, 2018 | 03:53 PM
52 Merc's Avatar
52 Merc
It's shown in the Ford Chassis Parts Catalog as Extension, Frame Side Member, p/n TCAA 5023-A. Used on 53-55 (which is as far as my catalog goes, it may service other years) F-350, 16 5/16" long. I don't know why, exactly, the F350 would need it and other pickups don't, unless it's an extension for a flatbed application or the extra long 9' pickup bed. If you're using a regular 8' pickup box, you may not need it.
Old Jul 29, 2018 | 05:26 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Hmmm, learn something new here all the time. I have the Ford Body Builders’ Layout Books for 1953, 1957, and 1966 that show frame details and specs. They all show pictures of this piece, as do the chassis catalogs, but no better description than Wayne posted. The TCAA 5023-A number changed to B7Y 5023-A then to C3TZ 5023-A. I ran a Parts Voice search on all three numbers with none found. Stu
Old Jul 29, 2018 | 06:34 AM
raytasch's Avatar
raytasch
Believe Nothing
Yes, I learned something too. A piece of channel iron could easily be made to work as an extension to make any bed fitment easier.
Old Jul 29, 2018 | 08:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
My O-S-I says that both TCAA-5023-A & B7Y-5023-A were obsoleted with no replacement numbers and C1TT-5023-E was replaced by C3TZ-5023-A
Old Jul 29, 2018 | 08:54 AM
truckdog62563
Oh, the C1TT 5023-E must have been a different design spec all together as used on the later model? The only models to use the extensions on the earlier trucks were the 1/2 ton panel (different number) and tonners that I saw in the catalogs. Stu
Old Jul 30, 2018 | 02:56 PM
petemcl's Avatar
petemcl
I agree. Here is what I did on my F2 that had the rear of the frame hacked off. I gave measurements to a local fab shop and they bent U-channels to the right size.
mgerdau
21
Oct 10, 2015 01:21 AM
linckeil
Jan 2, 2010 10:38 PM
wildstang
Paint & Bodywork
Jun 29, 2008 07:20 AM
bshackelford711
Jan 17, 2005 08:20 AM
