Water Heater Maintenance?
Received 6,718 Likes
on
While buying something for my truck on Amazon this popped up: http://a.co/1NVYZmS
I drain my water heater as part of my winterization process. Should I be cleaning the tank more thoroughly? The wand shown above appears to be a good way to do that. Reviews of the wand also said to do a 50/50 mix of vinegar/water to complete the process.
I see that as a very handy tool to have. I've noticed on mine that there is a bunch of sediment at the bottom of the heater that I can't flush out. This year I hooked up the hose and let the water flush out of the drain on the heater and poked around carefully at the bottom to stir up the sediment so that it could get flushed out.
handy indeed ... I think I'll order one!
awesome find!
awesome find!
Whether it's needed who knows folks been flushing tanks letting water flow out with no issues for along time, does it hurt to clean above and beyond certainly not. If it makes you feel better why not.
Making sure the rod is good and having clean threads when reinstalling is possible just as important.
And doesn't really work.
We have a lot of sediment in our water. So much that the lower element of my household water heater was buried!
So, I thought one of these would be good for the campers. The problem is, when you turn on the water, the pressure causes the tube to bend backwards so that the end of it ends up spraying straight ahead anyway. The only possible advantage it could have is to allow you to place the spray at the back of the tank, vs. merely spraying water into the opening.
How do I get the sediment out of the tank that resides below the drain plug?
hooking up the hose and letting it run doesn't get it. And letting the tank fill under some pressure and letting it rush out under garden hose pressure/flow didn't get it either.
is that an acceptable level of sediment in the tank?
on
That's what I was afraid of, folks thinking this is something that has to be done routinely. It most often takes literally years for screen to load up enough to slow water flow at the faucet and the one place I have seen it actually lead to service calls is folks who live off their pump and forget there is a sediment screen there. And it is still no big deal because you just clean off the screen when it becomes an issue. For folks who feel this is an issue they want to add to their worry list, it might be useful to add an inline filter to their hose and filter all the water that goes into their camper.
For folks who never thought about this and have never had a problem, my suggestion would be to go back to what you were doing before.
Steve
Steve
on
My trailer has a house filter system. It had no filter in it when I got it. I don't think the prior owner even knew there was a house filter system. When I fill up at home I don't use an external filter. When I fill up at a remote location I do use the external filter. So the water in my system gets filtered as many as two times. But I'm sure there are sediment deposits in the system from the house filter system not having the filter in it. I'm hoping that explains why the sink faucet has less flow than the bathroom faucet. Is there usually a screen inline before the water pump? Getting to that could be really interesting.
Cleaning the screens on faucets isn't that tough as long as the threads haven't become corroded. In the house I do it once every 10 years in the bathrooms. In the kitchen I never do it because faucets don't seem to last that long in our house.
