Flareside tailgate hinge/tail light configuration
Old 07-23-2018, 04:36 AM
benbuilder's Avatar
benbuilder
benbuilder is offline
I have a 66 that was completely taken apart when i got it. I put the tailgate hing and tail light together as i thought it was correct. I have the channel bumper. The parts book does not give a clear picture of how they go together. I bought a 68 Flareside this past weekend for the bumper and brackets and noticed a different configuration than what i have. Anyone know what is correct? The orange pictures are of my truck. I have taken pictures of opposite sides of each truck, but the mounting configuration is the same. The red rusty mess is the parts truck. Thanks
Old 07-23-2018, 08:10 AM
Bert65's Avatar
Bert65
Bert65 is offline
My 65 has 3 holes
The middle of the 3 holds the bottom of light bar on back and the top of the hinge on front
I dont see why your setup would not work though
Old 07-23-2018, 12:25 PM
daveengelson's Avatar
daveengelson
daveengelson is offline
On my 65 Flareside the tail-light and tail-gate brackets are mounted together and my initial thought is because of the barton bumper support bracket however, and although I found it difficult to determine from the diag in the Ford truck Master Catalog appears to be mounted the same way. Looking forward to member's input. If time permits I will attempt to fire up the scanner and post diag. Personally I like the appearance of the way U have the taillight mounted.
and taillight bracket are mounted from the front using the same 2 holes.
Old 07-23-2018, 04:21 PM
Bert65's Avatar
Bert65
Bert65 is offline
curious if there may have been options
i am rebuilding mine and as mentioned it has 3 holes on each side
I ordered bolt kit with long acorn nuts from NPD and the kit has 6 bolts, so assumed it was 3 on each
Old 07-23-2018, 05:40 PM
benbuilder's Avatar
benbuilder
My 66, i replaced the posts with new from NPD. I didnt have much to go by on the originals, so i dont know what is correct.
Old 07-25-2018, 11:05 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
8C-8343018 .. Tailgate Hinge - Right/Left is the same / Reproduced
1948/52 F1/F3; 1953/79 F100/350 Flaresides.
arthall
01-31-2019 07:22 AM
Chulke
11-18-2018 09:19 PM
HILLBILLY BOB
07-08-2018 06:50 PM
Bohen
6.7L Power Stroke Diesel
03-13-2017 05:58 AM
mountie
1999 to 2016 Super Duty
04-04-2016 06:39 PM
Quick Reply: Flareside tailgate hinge/tail light configuration
