running issue
Old Jul 25, 2018 | 05:21 PM
RadioControlGuy85's Avatar
RadioControlGuy85
Originally Posted by matthewq4b
Ya that is the mega Ohm setting. Try again with the noted settings.
what you be the noted range?
there
2m
200k
20k
2k
200
Old Jul 25, 2018 | 05:24 PM
matthewq4b's Avatar
matthewq4b
Refere back to post #14 Pos post to neg post should just be ohms and neg to plug post should be 1K ohms.
Old Jul 25, 2018 | 05:42 PM
RadioControlGuy85
yep same reading
Old Jul 25, 2018 | 05:54 PM
matthewq4b's Avatar
matthewq4b
there
2m
200k
20k
2k
200
For your meter Pos and Eng should be on the 200 Ohms the Neg to coil lead 20K
If you are still getting the same readings the coil is NFG.
Just to note coil should be disconnected when testing.
Old Jul 26, 2018 | 01:09 AM
RadioControlGuy85
yea i had it disconnected,
came out with the same reading
Old Jul 27, 2018 | 08:17 AM
RadioControlGuy85
ok i switch coils with my other truck and the truck still ran like crap, and the other one is still running great, so its not the coil.
Old Jul 27, 2018 | 03:26 PM
matthewq4b's Avatar
matthewq4b
Well you have ruled out basic ignition stuff. Time to compression check and check for vacuum leaks. And define running like crap. Post a video if you can.
Old Jul 27, 2018 | 05:33 PM
FuzzFace2's Avatar
FuzzFace2
Ok don't know how you got on to the coil switch but did you get codes and if so what were they as I don't think I seen them posted?
You said it smelled rich. Pull the new plugs and tell us what they look like or better yet post up pictures of them.
Have you done a compression test so we know what we are working with?
Dave ----
edit: I should of posted this hours ago when I started typing it.
Old Jul 27, 2018 | 06:41 PM
matthewq4b's Avatar
matthewq4b
Dave ----
They suspected bad condenser so safe to assume they believed it was ignition related. Plus no start when hot. If that is a person's first thought then that is the first thing to check. Regardless it is ruled out.
Pulling codes in this case will be no help as all it will do is tell if the O2 is shot TPS is shot or stepper motor in the carb is done for. None of which would cause the issues he is having.
Old Jul 28, 2018 | 05:50 AM
RadioControlGuy85
i try and get a video in a bit,
Old Jul 28, 2018 | 08:24 AM
RadioControlGuy85
as you see in the video, when i rev it, it sounds fine, the past week it would not rev that smooth or sound that good, and no its not out of gas.
Old Jul 28, 2018 | 08:54 AM
FuzzFace2's Avatar
FuzzFace2
So not going back thru the posts why pulling the code will tell the O2 is shot TPS is shot or stepper motor in the carb is done for?
If that is the case and the computer is trying to compensate for them no wonder it runs like crap and hard start when hot.
If the computer is not controlling and older parts used to make it run right, then I can see why the coil change.
I would still like to know what the compression is & the plugs look like even more so that the IGN. has been ruled out so far.
Based on the user posting smelling gas I think it is a fuel / carb issue. Boiling fuel when hot can cause a hard start when hot.
Dave ----
Old Jul 28, 2018 | 09:07 AM
  #28
RadioControlGuy85
Dave ----
the plugs are black, dont have a compression tester,i doubt the motor is hurt,
Old Jul 28, 2018 | 12:00 PM
  #29
FuzzFace2's Avatar
FuzzFace2
Black plugs is a sign of it running rich maybe time for a carb rebuild?
Also fouled plugs will make the motor run ruff & miss.
BTW I had a plug foul from running too lean. They were new and the motor only runb the get the car in & out of the garage or on & off trailer.
Started one day to move and anything more than an idle it would back fire out the exh.
At first I thought stuck valve but compression test showed other wise.
I found what cly was not firing, moved the new looking plug to a different cly.and found it was the plug.
New plugs fixed the miss fire and a new carb fixed the lean issue, rebuild would not fix it.
Dave ----
Old Jul 28, 2018 | 12:56 PM
  #30
RadioControlGuy85
Dave ----
i have checked all the plugs this morning and there all fireing, not one plug is dead,
