Linkage pics needed
Old Jul 22, 2018 | 05:33 PM
lostbrd's Avatar
lostbrd
Linkage pics needed
Swapping over to 4 barrel. Looking for any pics of modified throttle linkage from fire wall.
Thank you
Jason
Old Jul 23, 2018 | 03:56 PM
charliemccraney's Avatar
charliemccraney
For which year and which transmission?
Old Jul 23, 2018 | 04:28 PM
lostbrd's Avatar
lostbrd
54 f100
engine is 59 292 yblock with 3 on the tree overdrive
Old Jul 23, 2018 | 04:38 PM
charliemccraney
Has it already been modified so that it works with the '59 engine, presumable a 2 barrel or is this a totally new swap?
Old Jul 23, 2018 | 05:38 PM
lostbrd's Avatar
lostbrd
Yes. Engine was in truck ( with a 2 barrel) when I got it.
Old Jul 23, 2018 | 05:40 PM
lostbrd's Avatar
lostbrd
A little research tells me I need throttle linkage from a 6 cylinder
Old Jul 23, 2018 | 07:39 PM
charliemccraney
I don't know about '54s so I don't know if this will work for you but maybe it will give you an idea if not. In my '61, I used some all-thread with a spherical bearing rod end on the firewall end and a quick disconnect on the carb side. You can use rod ends on both sides and just bolt it to the carburetor - I had it setup like that for a long time. All but the quick disconnect can be found at a good hardware store. The stuff I'm using is stainless, which I ordered from Mcmaster-Carr. The quick disconnect came from Jegs, part number 555-15734.
You have to carefully cut the all thread to the right length to allow you to adjust the rod so that you get wide open throttle with the pedal to the floor. Too long and you don't get wide open, too short and you can damage the carburetor by pulling the throttle too far when you get on it.
Old Jul 23, 2018 | 08:07 PM
lostbrd's Avatar
lostbrd
Perfect! Thank you so much.
Jason
lostbrd
Jul 22, 2018 05:33 PM
low54
Jun 13, 2011 07:03 PM
WALFORD'S 56
May 7, 2008 10:12 AM
