Oil Pan leak
Old Sep 1, 2001 | 03:18 AM
wmcnally's Avatar
wmcnally
Oil Pan leak
I have a 1989 E-150 with a 5.8L Windsor. I had the valve cover gaskets changed because they were leaking very badly. I still have a leak from the oil pan gasket that needs to be fixed. I'm told by my mechanic that a "cross member" makes this a very difficult (expensive) job. I'm told the engine has to be "jacked-up" which I fear may cause other problems. Is there a better (i.e. cheaper) way to address this problem? Any help would be very appreciated.
Thanks in advance,
Bill
Old Sep 1, 2001 | 09:04 AM
cbwarrior's Avatar
cbwarrior
Oil Pan leak
I've changed one in a pick-up with V-8. All you need to do is loosen the motor mounts a little and lift the engine a couple inches. I unbolted the oil pickup tube and left it in the pan, swapped gaskets, and reinstalled the tube and tightened the mounts. There shouldn't be any after effects unless he is careless and lifts the engine too high and breaks/bends something.
88 F-150 4X4 XLT Lariat w/5.0 EFI 5 spd (DAILY DRIVER)
86 Ranger 2WD w/2.3L EFI 5 spd to be 351W 4bbl C4 (NEW TOY- DETAILS WHEN FINISHED)
85 Old Cutlass Supreme 350/TH350 Holley 4160,Edelbrock Performer intake, el-cheapo headers, General Kinetics 270H series cam, 15.588 best 1/4 mile with original 10 bolt 2.41 gears (OLD TOY)
Old Sep 1, 2001 | 09:52 PM
Craig01's Avatar
Craig01
Oil Pan leak
