Sponsored by: Real Truck
No tach, engine or trans temp
Old Jul 19, 2018 | 01:29 PM
Jeff Tarantino's Avatar
Jeff Tarantino
hello, I’ve gone round and round with this truck. I’ve seen a few threads with the same problem but no one ever posted their results. It’s an 04 f350 6.0 srw full 4dr. Did some welding on this truck and ever since it’s done all sorts of weird stuff. Sent cluster out first, that fixed many problems. But now I have no tach, engine and trans temp, check gauges light is on, check engine light is on and the WTS light stays on for a lot longer than normal. I know the sensors are working because they come up when I plug in my tuner and read the data. It looks like the wiring for those gauges come right from the pcm. So I ordered a new pcm and still does the same thing. There is no tune in the truck right now. I also have other weird bugs going on in the trick like the auto lights don’t work, the interior lights don’t come on with any door open, the radio doesn’t shut off when I open any door. But I think those are seperate from what I have going on with the cluster. Any help would be much appreciated! Thanks guys
Old May 1, 2019 | 07:57 PM
Jmartin7188's Avatar
Jmartin7188
Have you figured it out??!! I’m having those same exact issues
04 F350 6.0
Old May 2, 2019 | 05:48 AM
Jeff Tarantino
04 F350 6.0
i literally just got my truck back last week. Turns out I needed a ford cluster and ford pcm to fix my concerns. Just replacing one of those wouldn’t fix it. I had a company rebuild my old cluster which didn’t work, and I got a aftermarket pcm online somewhere that didn’t do anything. Got a used ford pcm, and a new cluster from ford(stupid money) and my cluster came back! Hope this helps!
Matt Manley
Jul 18, 2018 09:23 PM
04MWCC
Jan 11, 2016 05:39 AM
quakerj
Jan 22, 2014 01:40 PM
Rogue_Wulff
'80-'86 FAQs (Frequently Asked Questions)
135
Jul 9, 2010 05:23 PM
Capt Dan
Jan 9, 2004 09:28 AM
