Sponsored by: Real Truck
Wheel Fitment
Old Jul 20, 2018 | 08:03 PM
Markus Luukko's Avatar
Markus Luukko
Originally Posted by 00t444e
Been doing it for 4 years.
yeah that’s not safe at all if you’re running 33x12.5x16s on stock wheels your tire guy really doesn’t care for your safety
Old Jul 20, 2018 | 08:10 PM
00t444e's Avatar
00t444e
Originally Posted by Markus Luukko
Also your center line is at a different position for every different width wheel you have. 7 is 3.5 8 is 4 and 9 is 4.5. Therefore a wheel with -5mm on each wheel doesn’t mean the centerline is at the exact same position for each wheel if you’re following me
Your offset is your center line a 0 mm offset would be right in the middle of the wheel, so on a 8" wheel 0mm offset would be 4 inches or 3.5 inches on a 7" wide wheel.
What makes it unsafe? I have put 40,000 miles on it like that daily driving, towing, and aired down offroad, never had an issue. 315/75/16 (35x12.50x16) on stock wheels.
Old Jul 20, 2018 | 08:19 PM
Markus Luukko
Tire companies don’t advise letting that wide of a tire and that big of a side wall on 7 inch wide wheels, too much sidewalk sway
Old Jul 20, 2018 | 08:23 PM
00t444e's Avatar
00t444e
They don't advise you do go over the speed limit either, ever done that?
Old Jul 20, 2018 | 08:30 PM
Markus Luukko
My tires are rated for 106mph so no I haven’t good luck to you towing with those.
Old Jul 20, 2018 | 08:39 PM
00t444e's Avatar
00t444e
LOL I was talking about the posted speed limit but your right, not a great idea to go faster than the tire speed rating. As far as towing goes my tires have a 3860 lb load rating so no issues there, my axle ratings would be exceeded long before the tires would.
Old Jul 21, 2018 | 07:34 PM
wvdave's Avatar
wvdave
I have a 2016 F350 with stock 17x7.5" wheels. I would like to put a set of 2018 stock wheels on it, they are 18x8". I would like the 8" wheel so I can run a Cooper AT3 XLT with a 4080 E load rating. Can I do that with no problems?
Also, I have a set of take off Cooper SST Pro's that I would like to put on a 17x7.5" factory steel wheel for looks and to run while I'm not towing. What year factory wheels will fit my 2016 F350? Any, as long as they are 8 lug?
Old Jul 21, 2018 | 09:17 PM
00t444e's Avatar
00t444e
What size are the tires you want? As far as I know any 05 and up F250 or F350 srw wheels will fit your truck.
Old Jul 21, 2018 | 10:16 PM
wvdave's Avatar
wvdave
thank you! do you think the 2018 18x8" will fit it as well?
Old Jul 21, 2018 | 11:29 PM
00t444e's Avatar
00t444e
I believe the bolt patterns is the same 8x170 but the hub bore size may have changed on the 17 and newer models, I am not sure.
Old Jul 22, 2018 | 02:46 PM
Markus Luukko
Okay so now I’m having trouble with tire size. I will be leveling my truck so I know I “could” fit 35s but I don’t want them. I am looking at either 285/75r18 or 305/60r18 for tires. If I get 285s I have a plethora of tires to choose from, if I get 305s I’m stuck between a few tire options. But the real issue is rubbing, I have no idea if 305s will rub or not I know 285s won’t but I think the 305s would look better on the truck. If anyone knows if 305s would rub or not let me know. TIA!
Old Jul 22, 2018 | 03:22 PM
00t444e's Avatar
00t444e
What rim offset and is it stock or lifted?
Old Jul 22, 2018 | 05:03 PM
  #28
Markus Luukko
-12mm and the truck will be leveled shortly, trying to figure out how I want to go about the level if you have any recommendations, currently deciding between lift shackles and x code leafs. But I have a new track bar I want to use and idk if I can use it with either.
Old Jul 22, 2018 | 08:24 PM
  #29
00t444e's Avatar
00t444e
I know for a fact that a 305/70/16 on a -12 mm offset wheel fits great on a leveled truck with room to spare. So you shouldn't have an issue fitting a 305/60/18.
Old Jul 22, 2018 | 09:02 PM
  #30
Markus Luukko
Thank you, now I need to figure out if I need to get an adjustable track bar with my x code leafs
