93 302 cuts off
Old Sep 22, 2003 | 01:36 PM
jkoon11's Avatar
jkoon11
93 302 cuts off
sometimes, when stopped like at a red light or stop sign, when i give it gas it either cuts off or comes close to cutting off. also when making a turn at a slow speed it just dies. but it always cranks right back up. i took in in and had a new "idle air control valve" put on and that solved the problem for about a month or so and now it is happening again. i dont know much about truck so any help would be appreciated. also how hard is it to put a new starter on? like it said i dont know much but im pretty good at figuring things out an learning what i dont already know.
Old Sep 22, 2003 | 01:59 PM
jkoon11's Avatar
jkoon11
93 302 cuts off
come on guys......
Old Sep 22, 2003 | 02:10 PM
stepman's Avatar
stepman
93 302 cuts off
Maybe bad TPS? Do you have autozone you could go to to see if it has any codes stored?
Old Sep 22, 2003 | 02:12 PM
jkoon11's Avatar
jkoon11
93 302 cuts off
sorry man, forgive my ignorance.....what is a tps?codes? yes i have an autozone
Old Sep 22, 2003 | 02:34 PM
stepman's Avatar
stepman
93 302 cuts off
TPS is throttle position sensor. Codes are usually stored in the computer when a sensor fails or the comp sees a problem. Ther is a diagnostic connector that is used to "hook-up" to the computer and get info out of it. If you go to autozone, they should be able to "read" any codes for free.
Old Sep 22, 2003 | 03:20 PM
jkoon11's Avatar
jkoon11
93 302 cuts off
thanks, any advice on new starter installation?
Old Sep 22, 2003 | 03:26 PM
stepman's Avatar
stepman
93 302 cuts off
The starter shouldn't be too hard. Disconnect the batt. neg. cable, there should be 2 bolts holding it in, and then a cable on the starter. Biggest problem with starters is usually the bolts can be hard to get at or there isn't a lot of room when dropping it out.
