replacing antenna
Old Sep 22, 2003 | 12:41 PM
dotcentral's Avatar
dotcentral
Question replacing antenna
My antenna is broken off. If someone standing outside the truck touches the broken off shaft, the reception comes in great, so I take it the cable is still good. How do I remove and replace the old antenna? Do I need to take the dash apart? Take the radio out? Glove box?
Old Sep 22, 2003 | 01:20 PM
seattlecyclops's Avatar
seattlecyclops
replacing antenna
I too faced the same challange. The antenna is on the right hand side, close to the curb and invites any juvie to twist it off. It looked like a bear to replace so I moved my antenna to the left, leaving the broken one in place. It was still a chore to drill through two layers of fender/cowling to pass the cable through but was worth it. I really like the left placement as I can now load long things from the right without worry. I also park the truck next to a tree and the branches treatened the antenna every time I parked. This approch solved a number of problems, may offend some purists and works great for me.
Old Sep 22, 2003 | 01:40 PM
NM5K's Avatar
NM5K
replacing antenna
You used to be able to buy whips that could attach to the stub that is left on that mount if it's long enough to attach to. Might be an easy option if you can find one. MK
Old Sep 22, 2003 | 01:50 PM
Mike W's Avatar
Mike W
replacing antenna
I would do that also. They have a set screw to hold them on.
Old Sep 25, 2003 | 10:45 AM
socaljerry's Avatar
socaljerry
I just insalled an antenna on my old truck I bought at the junkyard for $5.00. It took me about 15 min. to install.
(four screws).
Old Oct 7, 2003 | 12:31 AM
67f100's Avatar
67f100
Try an antenna of of a mid eighties ford car(like a mustang,taurus, etc) they hava a whip and if you do get it broke you can just screw one back in.
