1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
#12 fuse keeps blowing 2006 Navigator
Old 07-16-2018, 05:42 PM
Gator06's Avatar
Gator06
Gator06 is offline
I have changed the fuel pump and the fuel pump driver module. I have checked multiple ground wires and still can't find anything. The fuse pops as soon as you turn the key. I have put higher amperage fuses and it still doesn't work. Desperate at this point. Any suggestions?
Old 07-17-2018, 08:41 AM
2trux's Avatar
2trux
2trux is offline
Sounds like a direct short to ground on the wire. Trace the wire from the fuse box to the end and look for bare wire or other damage. This is probably not a ground wire issue.
Old 07-17-2018, 11:28 PM
Gator06's Avatar
Gator06
Gator06 is offline
Apparently the short is between the fuel pump inertia switch and the fuel pump driver module
Old 07-18-2018, 06:23 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
What is the history of the beginning of the problem?
Old 07-18-2018, 06:24 PM
pdqford's Avatar
pdqford
pdqford is offline
^ What he said.
rmh1999
06-02-2023 11:40 PM
James Annese
1997 - 2003 F150
11-18-2018 03:21 PM
waynec423
Electrical Systems/Wiring
08-14-2018 05:26 PM
Kevin McCutcheon
1999 to 2016 Super Duty
08-04-2016 11:51 PM
sean9049
02-26-2015 03:23 PM
Quick Reply: #12 fuse keeps blowing 2006 Navigator
