Rear gears question
And since you said you saw the dyno sheet at 400 hp. I'd wager low end tq is way down. I wouldn't put anything less than 4.56s in it.
And as for more practical, it may not be. The truck computer rev limiter will most likely kick in before peak horsepower is made, and it may actually be weaker as a truck because of the rpm range the cam makes its power in.
Also without a tune you will, depending where this engine makes power. You will have to manually shift the trans. Because the computer will shift at the factory programmed rpm, it may shift a 1000 rpm before the engine wants it to.
Thank you
I must have missed the post when you said it was different.
brushtrooper, with the small 5.0 and no power adder, it'll take a loose converter AND gears to get it going from a dig. How loose and how much gear depends on how fast you're looking to go. But guessing you already know that. Tire size will depend on ride height and taste, I prefer at least a 30" tire to fill the opening.
The E4OD overdrive will lower rpm to around 3193rpm
4.56 should get you 3591 rpm in 3rd & 2941rpm in OD @ 75mph
4.11 should get you 3236/2586 respectively
RPM = (mph x axle ratio x 336) / actual tire size
I believe OD is a ratio or percentage but I figure ~650rpm reduction to get close.
That post I put above, I have been witness to a b-cam 302 in a truck with an auto. Super sluggish till 3-3200 then it revs quick to the shift point but the trans can't shift fast enough. So it sounds like a 2 step between gears. Only thing that may help low end is staying with the mustang intake. With the smaller cross section of the runners it may keep port velocity up.
I could have sworn mine was about 650 difference. Good to know.
I see that I will need to pay more attention to my tach next time I'm rolling down the freeway.
4:11
4:56
4:88
These are the gear options we are looking at and truck will have a 2500 stall. I am thinking we will go with MT 31x16.5x15LT for the tires. How would you figure RPMs at the end of the track? I am thinking you want to come across the line at the upper end of the RPM range being in 3rd(drive). Is there a way to calculate this for a best guess estimate?
I really like the idea of 4:88's but do not want to run out of motor at the end of the 1/4
Open to ideas and suggestions
If you are running on the truck computer, a 4.56 will max out at rpms in 3rd at 110. But, 110 is a bit optimistic for a 5.0 powered truck in the quarter.
And 4.88s will max out in 3rd at 95.
...MT 31x16.5x15LT for the tires. How would you figure RPMs at the end of the track? I am thinking you want to come across the line at the upper end of the RPM range being in 3rd(drive). Is there a way to calculate this for a best guess estimate?
Here's another one of the many calculators out there: https://www.yukongear.com/calc_rpm.aspx
I don't know quarter-mile tech or strategy, but expect a lot to depend on how the engine is built, like Mudsport was asking. Gearing and tire size are going to get you your rpm levels at given speeds, but only you know how the engine is going to be breathing at those speeds.
Like you were thinking then, if you don't want it to run out of breath before you reach the trap (and won't that vary by day, temps, track, lane, etc. every run anyway?) you need to build the gear a little taller.
But like all racing, it's a balance that has to be struck. Not just one gear choice based on what we think might be best without knowing anything more about the truck's overall performance. That is something only the end-users/drivers/racers will be able to figure out in the end. And it might change after the fact, even then.
I think all the recommendations and suggestions given so far have been pretty spot on when they can be.
For calculating chart purposes, any way to find out what the actual height of the tire is? And of course, for that final bit of fine-tuning your calculators, you'd need to know the exact rolling diameter of the tire with the full weight of the truck on top of it at normal air pressure.
If we assume a 30" tall tire for now, a 4.56 gear ratio will put you just over 5200 rpm at 100mph in third. Do you want to use overdrive in drag racing? I'm wondering, since OD is often the weak link in a transmission, auto or manual. But with a built tranny? I don't know.
At that same ratio on the street cruising along at the 75mph I think you mentioned originally, you're only pushing just under 2700 rpm in overdrive. That's no problem for the engine, but what is it doing with all that frontal area trying to push through the wind? Dunno, but you're going to find out!
I guess the bottom line is that with an overdrive trans you do have some leeway, especially on the street. You could go to 4.88's and be at 5600rpm at 100mph in 3rd gear, or cruise along nicely at about 2900 in 4th at 70mph.
The question remains though, do you think you'll be pushing 100mph at the end of the 1/4, or some other speed? More? Less? It's a lot of truck even for a warmed up 5.0. But with low gearing and the ability to rev above 6000rpm without doing any harm, and you could be dialing it in.
You're going to have to know your motor and trans build more than just about anything else then. Notice on that page I linked to up in the address bar you'll find links to other charts/calculators that will let you start with different categories. So you can start with a target rpm, and see what gear ratio will put you there with your tire size. Plus a couple more choices of starting point.
You'll have to make some assumptions initially about how fast you think you'll be traveling at the end, but that'll be easy... After the first couple of runs that is!
Good luck.
Paul
Maybe 4.56 is the better choice and fine tune with tire size. Trying to stay with in budget as changing gears multiple times is not feasible.
Thanks for the help
Wallace Racing - Automotive Calculators
They have calculators for tire size, RPM, ET, HP, all kinds of stuff. Gives you some ballpark information.
