Engine runs really rough, possible cause?
Old Jul 12, 2018 | 03:53 PM
gavin68's Avatar
gavin68
Hey everybody,
I've got a '68 F-100 that recently got a "new" 360 from a '74 f250. The only modifications are an aluminum intake, edelbrock 1406, long tube headers, msd coil, and plug wires.
After the installation it wouldn't start, just backfired like crazy, the distributor was 180 off so we pulled it out and installed it correctly. It'll fire right up now but it runs really rough, and won't stay running. (won't really idle, have to be on the gas a little to keep it running for more than a couple seconds) Timing should be close enough to run pretty well, any idea what the issue could be? My only other guess would be fuel delivery but the carb was recently rebuilt.
Any help is greatly appreciated, I'm 16 years old and have very limited knowledge when it comes to classic vehicles
Old Jul 12, 2018 | 10:24 PM
Burnt Rubber's Avatar
Burnt Rubber
It could be any number of things. Did you hear/see the engine run before you installed it? Have you done a compression test? An engine needs 4 things to run: Fuel, spark, air and compression. Something is not right. Do you have a vacuum leak?
Devin
Old Jul 18, 2018 | 04:59 PM
JEFFFAFA's Avatar
JEFFFAFA
What do you mean by "new" engine? New to you or rebuilt? If rebuilt, who rebuilt it? Who rebuilt the carb and why?Did you hear it running in the donor truck?
Here is a few things to check.
1. Make sure wire from ignition switch is on the "+" coil terminal. "-" goes to Dizzy (distributor).
2. Double check plug wires to be in the correct firing order. Note below Ford numbers their cylinders different than Chebbie and Chrysler.
3. Make sure there is gas in the carb. With engine NOT running look down the throat of the carb. Move the throttle back and forth a couple times. Look for the accelerator pump nozzles to be squirting two strong squirts.
4. If there is old gas in the tank, drain it and add new gas.
Dustin_in_PDX
Oct 14, 2017 05:51 PM
Pappys53
35
Mar 30, 2014 08:15 AM
pditmars
27
Sep 18, 2013 03:51 PM
brokersteve
Dec 11, 2012 04:35 PM
autoworks
Dec 20, 2008 05:53 PM
