Fuel tank issue
Old Jul 9, 2018 | 11:42 AM
Whitty121's Avatar
Whitty121
Fuel tank issue
Hi, I’m having a big issue with my truck.
i replaced the front tank pump yesterday, it all went well. Truck runs great.
its pushing gas from the front tank to the rear tank though, the rear tank doesn’t work, the pump was gone when I bought it.
i really don’t want to put a second pump in the rear tank, I won’t use it anyway I’m sure.
what can I do, is there a check valve gone or have I got to replace the pump to stop it leaking. It’s so full it’s coming out the rear tank filler neck.
Old Jul 9, 2018 | 01:32 PM
FuzzFace2's Avatar
FuzzFace2
You didn't say what year, model & motor as it can make a difference how the duel tanks are set up.
Some have a 6 port switching valve that can hang up, and others I here have a check valve in the pump that the tank doesn't have.
BTW how you going to get that gas out?
Dave - - - -
Old Jul 9, 2018 | 03:33 PM
Whitty121's Avatar
Whitty121
You are correct I apologise, it’s a 1995 5.0 Eddie bower 2wd
Old Jul 9, 2018 | 05:50 PM
Conanski's Avatar
Conanski
The check valves are inside the FDM that contains the fuel pump inside the tank, so your only options are replace the rear tank FDM or disconnect and plug both fuel lines to the tank..
Old Jul 9, 2018 | 09:42 PM
Whitty121's Avatar
Whitty121
Thank you so much. New pump ordered. Hope the tank isn’t rusty inside. Front one was good.
i got some pb working on the bolts.
I did notice something odd, my tow hitch is welded on !
JYost17
Nov 5, 2016 09:55 AM
rsulvan
Aug 20, 2006 11:20 AM
1982fordf100
Jul 27, 2006 12:26 PM
zerocash
Jul 27, 2004 08:10 PM
moose94
Apr 10, 2004 10:43 PM
